Invalid input error when trying to define a vlan access-map
tacit.cheddar
Visitor
VACL design question Vlan Access map
I have a primary switch connected with 2 secondary switches. They contain vlans 10,20,30,40,50, and 60. I need vlan 10 to be able to communicate with all the other vlans. I need vlan 20 to be able to communicate with vlans 30 and 40. Vlans 30,40,50, and 60 should not be able to communicate with other vlans. My understanding is I need to create access control lists and use VACL access-mapping to apply them. Am I mistaken? When I try to define the access map I get an invalid input error:
SW1(config)#ip access-list extended ALLOW_ALL
SW1(config-ext-nacl)#permit ip any any
SW1(config-ext-nacl)#vlan access-map VACL_10
% Invalid input detected at '^' marker.
what am I doing wrong?
thanks!
Georg Pauwen
it looks like you are in the wrong mode:
You need to be in global config mode:
SW1(config)#vlan access-map VACL_10
I changed the mode, now I'm getting an invalid input error with the carrot
under the 'a' in access-map.
SW1>en
SW1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
SW1(config)#vlan access-map VACL_ALLOW
SW1(config)#
any thoughts?
thanks!
what are your options after 'vlan':
SW1(config)#vlan ?
Which switch model and IOS version do you have ? Post the output of:
sh ver
I grateful for the help. I’d be embarrassed to say how long I’ve been
struggling trying to figure all this out. here’s the output for SW1#vlan ?
….I tried that earlier but didn’t know what to do with the options it
presented. Below that is the sh ver.
##### vlan ? options #########
SW1>en
SW1#conf t
SW1(config)#vlan ?
<1-4094> ISL VLAN IDs 1-1005
SW1(config)#vlan
SW1#sh ver
Cisco IOS Software [Denali], Catalyst L3 Switch Software
(CAT3K_CAA-UNIVERSALK9-M), Version 16.3.2, RELEASE SOFTWARE (fc4)
Technical Support : http://www.cisco.com/techsupport
Copyright(c) 1986 - 2016 by Cisco Systems, Inc.
Compiled Tue 08 - Nov - 16 17:31 by pt_team
Cisco IOS-XE software, Copyright(c) 2005 - 2016 by cisco Systems, Inc.
All rights reserved.Certain components of Cisco IOS - XE software are
licensed under the GNU General Public License("GPL") Version 2.0.The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.You can redistribute and / or modify such
GPL code under the terms of GPL Version 2.0.For more details, see the
documentation or "License Notice" file accompanying the IOS - XE software,
or the applicable URL provided on the flyer accompanying the IOS - XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 4.26, RELEASE
SOFTWARE (P)
test uptime is 7 hours, 33 minutes
Uptime for this control processor is 7 hours, 36 minutes
System returned to ROM by Power Failure
System image file is "flash:/cat3k_caa-universalk9.16.03.02.SPA.bin"
Last reload reason : Power Failure
A summary of U.S. laws governing Cisco cryptographic products may be found
at:
[email protected].
Technology Package License Information :
Technology - package Technology - package
Current Type Next reboot
ipservicesk9 Permanent ipservicesk9
cisco WS-C3650-24PS (MIPS) processor (revision N0) with 865815K/6147K bytes
of memory.
Processor board ID FDO2031E1Q6
1 Virtual Ethernet interface
28 Gigabit Ethernet/IEEE 802.3 interface(s)
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
250456K bytes of Crash Files at crashinfo : .
1609272K bytes of Flash at flash : .
0K bytes of at webui : .
Base ethernet MAC Address : 00:50:0F:40:20:D9
Motherboard assembly number : 73-15899-06
Motherboard serial number : FDO20311WHP
Model revision number : N0
Motherboard revision number : A0
Model number : WS-C3650-24PS
System serial number : FDO2031Q0TD
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24PS 16.3.2 CAT3K_CAA-UNIVERSALK9 BUNDLE
Configuration register is 0x102
