IOS Copy for Switch 6500 with Sup-720
sepideh.ta
hi
I have 2 Chassis 6506-E with sup 720. one of them work properly(Switch1) but another(Switc2) not boot form bootdisk and go to ROMMON mode. I Captured IOS from Switch1 with tftp but I cant Copy this image to switch 2 with tftp.
Please help me what should I do?
tanks
Leo Laohoo
You said that Supervisor 1 is running OK using the IOS from CF?
Use the same CF to boot off the Supervisor 2.
hi
no, supervisor1 running ok but from bootdisk no CF,
I could used tftp or CF for boot supervisor2? If yes how to do it?
tanks
You can't use TFTP on the 2nd supervisor card.  The fastest way is to copy the IOS from the 1st Supervisor card to a CF.  Eject the CF from the 1st Supervisor card, and insert into the 2nd Supervisor card and, in ROMmon, tell the 2nd Supervisor card to boot the IOS from the CF.
in the RMON prompt ,type command boot disk0: and press enter
ensure you have CF installed  disk 0 and have proper IOS in it
Process example
Rommon 1 > dev
Devices in device table:
id name
bootdisk: boot disk
disk0: PCMCIA Disk 0
disk1: PCMCIA Disk 1
eprom: eprom
Chek for proper IOS
rommon 2 > dir disk0:
Initializing ATA monitor library...
Directory of disk0:
2   124931652 -rw-  c7600s72033-adventerprisek9-mz
7628  29351936  -rw-  c7600-fpd-pkg.122-33.SRE5.pkg
rommon 3> boot disk0:c7600s72033-adventerprisek9-mz.122-33.SRE5.bin
