06-02-2014 03:17 PM - editado 03-07-2019 07:36 PM
I have a ws-c2960-48tc-l switch with ios version: " C2960 Software (C2960-LANBASE-M), Version 12.2(44)SE2, RELEASE SOFTWARE (fc2) ",
JUAFINASW1#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(44)SE2, RELEA
SE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 01-May-08 12:45 by antonino
Image text-base: 0x00003000, data-base: 0x01000000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE
(fc1)
JUAFINASW1 uptime is 23 hours, 4 minutes
System image file is "flash:c2960-lanbase-mz.122-44.SE2/c2960-lanbase-mz.122-44.
SE2.bin"
I need to upgrade to version 12.2(50)SE5, I do all steps for that and install the image file: " c2960-lanbasek9-mz.122-50.SE5.bin ", afther that the switch starts and save all configurations, but I can not see, it is not pinging and can not does telnet using the ip address, I was to downgrade the ios to previous version.
It has connected usign Gig 0/1 port and it is configured only with switchport mode trunk,
The core switch has the follow configuration on the link port
speed nonegotiate
spanning-tree portfast disable
I upgrade other switches from same model and all works, but I don't know why this switch is not responding.
em 06-04-2014 08:23 AM
I would get a console on the switch in question and check the VLAN interface has come up correctly?
em 06-10-2014 07:43 AM
There is the information
JUAFINASW1#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
JUAMDF1SW1 Gig 0/1 144 R S I WS-C4503 Gig 1/13,,,, this is the link to core switch
JUAFINASW2 Gig 0/2 153 S I WS-C2960- Gig 0/1
JUAFINASW1#
This are the configurations on the switch WS-C2960-45TC-L
interface GigabitEthernet0/1
interface GigabitEthernet0/2
em 06-10-2014 07:46 AM
Can you do a 'show ip interface brief' ?
em 06-11-2014 08:40 AM
There is the show ip interface brief:
JUAFINASW1#show ip interface brief
Vlan1 10.131.0.10 YES NVRAM up up
FastEthernet0/1 unassigned YES unset up up
FastEthernet0/2 unassigned YES unset up up
FastEthernet0/3 unassigned YES unset up up
FastEthernet0/4 unassigned YES unset up up
FastEthernet0/5 unassigned YES unset up up
FastEthernet0/6 unassigned YES unset up up
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset up up
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset down down
FastEthernet0/11 unassigned YES unset up up
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset up up
FastEthernet0/14 unassigned YES unset up up
FastEthernet0/15 unassigned YES unset up up
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset up up
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset up up
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset up up
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset down down
FastEthernet0/25 unassigned YES unset down down
FastEthernet0/26 unassigned YES unset up up
FastEthernet0/27 unassigned YES unset up up
FastEthernet0/28 unassigned YES unset down down
FastEthernet0/29 unassigned YES unset down down
FastEthernet0/30 unassigned YES unset up up
FastEthernet0/31 unassigned YES unset down down
FastEthernet0/32 unassigned YES unset down down
FastEthernet0/33 unassigned YES unset up up
FastEthernet0/34 unassigned YES unset down down
FastEthernet0/35 unassigned YES unset up up
FastEthernet0/36 unassigned YES unset up up
FastEthernet0/37 unassigned YES unset down down
FastEthernet0/38 unassigned YES unset up up
FastEthernet0/39 unassigned YES unset up up
FastEthernet0/40 unassigned YES unset up up
FastEthernet0/41 unassigned YES unset up up
FastEthernet0/42 unassigned YES unset up up
FastEthernet0/43 unassigned YES unset down down
FastEthernet0/44 unassigned YES unset up up
FastEthernet0/45 unassigned YES unset up up
FastEthernet0/46 unassigned YES unset up up
FastEthernet0/47 unassigned YES unset down down
FastEthernet0/48 unassigned YES unset up up
GigabitEthernet0/1 unassigned YES unset up up
GigabitEthernet0/2 unassigned YES unset up up
JUAFINASW1#
em 06-11-2014 08:53 AM
So Gig0/1 is connected to the WS-C4503?
And your VLAN1 interface (10.131.0.10) is up but you can't PING the 4503 from this directly connected switch?
I assume you are trying to PING the VLAN1 interface address of the 4503?
And it worked before you changed the IOS?
em 06-12-2014 10:12 AM
that is correct, before I upgrade the IOS version I can ping from vlan1.
I did the upgrade, after that I can not ping from Ws-C2960 and from any outside PC or switch
em 09-29-2015 10:51 PM
Might be worth asking the service provider what Layer 2 MAC Address they have against your connection.
Its not unheard of for the mac to stick
You should ensure your mac address table is cleared also for assured connection.
Another cause of this could be quick swapping of connections....can cause problems at layer2
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
