IP address on a particular interface
iifanatic
I have a very stupid question here. Please bear with me as I am new to Cisco Routers.
I wish to set an IP Address say 192.168.100.1 255.255.255.0
So on the prompt I shoot the following commands:
enable
config t
interface ethernet 0
ip address 192.168.100.1 255.255.255.0
But now I wish not to set IP Address on this interface .. or in other words I wish to delete or erase this IP Address.
How can we do this?
2 Accepted Solutions
spremkumar
Level 9
Level 9
You can simply remove the ip address using no ip address 192.168.100.1 255.255.255.0 under the interface mode but u need to make sure that you are not accessing the router via the same ip address.
if you are connected via the same ip address you will get disconnected and might result in a reset to the hardware..
It will be safe if you are connected via console and doing the config..
regds
kerek
Level 4
Level 4
There are two ways:
no ip address
or
ip address x.x.x.x y.y.y.y which actually overwrite the previous IP address set.
If just want to delete the ip address use "no ip address".
Hope it helps,
Krisztian
spremkumar
Level 9
Level 9
regds
kerek
Level 4
Level 4
There are two ways:
no ip address
or
Hope it helps,
Krisztian
Thanks for your help guys.
The posts did solved the problem.
glen.grant
you can also do this.
conf t
default interface ethernet 0 .
