i havent tested this so i cant be sure but reading your post and checking against others it looks like a similar issue is known and there is a workaround , the link i provided earlier shows something related
https://www.cisco.com/c/en/us/support/docs/ip/address-resolution-protocol-arp/118630-technote-ipdt-00.html
Known Issue
The 'keepalive' probe sent by the switch is a L2 check. As such from the switch's point of view, the IP addresses used as source in the ARPs are not important: this feature can be used on devices with no IP address configured at all, so the IP source of 0.0.0.0 is not relevant.
When the host receives this messages, it replies back and populates the destination IP field with the only IP address available in the received packet, which is its own IP address. This can cause false duplicate IP address alerts, because the host that replies sees its own IP address as both the source and the destination of the packet; refer to the Duplicate IP Address 0.0.0.0. Error Message Troubleshoot article for more information about the duplicate IP address scenario.
Then it links off to this document explaining the duplication further
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/8021x/116529-problemsolution-product-00.html
A user post also discusses it on the forum , linking that doc
https://community.cisco.com/t5/identity-services-engine-ise/ip-device-tracking/td-p/3710912
is this what your seeing or is it something totally different in logs ?
