ip device tracking issue on 2960S-48TS-L
snyggsomfan
We are authenticating users and printers via dot1x and MAB towards the ACS 5.1. The ACS then pushes out a VLAN + an access-list. Sometimes printers (MAB) and users (dot1x) end up on the wrong VLAN even though I can see that the correct VLAN is pushed out from the ACS and received on the switch. Even if I shut down the switchport for a while the device still ends up on the wrong VLAN. The workaround for this issue is to enter the command "clear ip device tracking int x". Is this normal behavior? Doesn't it work to shut down the switchport or should I disconnect the end device completely from the switch for a while in order for the device tracking feature to clear the old entry? Below is relevant logs and config:
Correct VLAN = 50
Wrong VLAN = 666
SW on switch = c2960s-universalk9-mz.122-55.SE2.bin
interface GigabitEthernet1/0/14
switchport access vlan 666
switchport mode access
ip access-group pre in
authentication event fail action next-method
authentication open
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer restart 3600
authentication timer reauthenticate server
authentication violation restrict
mab
dot1x pae authenticator
dot1x timeout tx-period 5
dot1x max-reauth-req 1
001891: Sep 28 12:14:40: %AUTHMGR-5-START: Starting 'mab' for client (abcd.abcd.abcd) on Interface Gi1/0/14 AuditSessionID 0A0F0C060000014B50FCBA1F
001892: Sep 28 12:14:40: %MAB-5-SUCCESS: Authentication successful for client (abcd.abcd.abcd) on Interface Gi1/0/14 AuditSessionID 0A0F0C060000014B50FCBA1F
001893: Sep 28 12:14:40: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (abcd.abcd.abcd) on Interface Gi1/0/14 AuditSessionID 0A0F0C060000014B50FCBA1F
001894: Sep 28 12:14:40: %AUTHMGR-5-VLANASSIGN: VLAN 50 assigned to Interface Gi1/0/14 AuditSessionID 0A0F0C060000014B50FCBA1F
001895: Sep 28 12:14:40: sw_host_track-ev:pm_vp_removed message posted for GigabitEthernet1/0/14 vlan 666
001896: Sep 28 12:14:40: sw_host_track-ev:MSG = 5
001897: Sep 28 12:14:40: sw_host_track-ev:pm_vp_added message posted for GigabitEthernet1/0/14 vlan 50
001898: Sep 28 12:14:40: sw_host_track-ev:MSG = 4
001899: Sep 28 12:14:40: sw_host_track-ev:Disable Event on GigabitEthernet1/0/14 vlan 666
001900: Sep 28 12:14:40: sw_host_track-ev:Disabling host abcd.abcd.abcd, 192.168.5.5 on interface GigabitEthernet1/0/14
001901: Sep 28 12:14:40: sw_host_track-ev:abcd.abcd.abcd Stopping cache timer
sh ip dev track all
IP Device Tracking = Enabled
IP Device Tracking Probe Count = 3
IP Device Tracking Probe Interval = 30
  IP Address     MAC Address   Vlan  Interface              STATE
192.168.5.5     abcd.abcd.abcd  666  GigabitEthernet1/0/14  INACTIVE
/K
7 Replies 7
snyggsomfan
bump
Anybody?
Hello Patrik,
I am afraid that this issue points to an IOS bug, as there is absolutely no reason why a shutdown port should retain its (incorrect) state, and why should a port randomly accept and ignore dynamically assigned VLAN. One of things to test would be upgrading the IOS. Also, if you have a TAC contract, they should definitely hear about this.
I am sorry to be not able to help you further here.
Best regards,
Peter
d.blakemore
I Have a similar problem with a 2960S and 2960 non S variant
the following has been authed by dot1x and supplied a vlan ID and a simple ACL
g23219ca18.es#sh authentication sessions interface gigabitEthernet 1/0/3
            Interface:  GigabitEthernet1/0/3
          MAC Address:  109a.dd54.0d3e
           IP Address:  132.234.113.96
            User-Name:  s578473
               Status:  Authz Success
               Domain:  DATA
       Oper host mode:  multi-domain
     Oper control dir:  both
        Authorized By:  Authentication Server
          Vlan Policy:  10
         Per-User ACL:  permit ip any any
      Session timeout:  N/A
         Idle timeout:  N/A
    Common Session ID:  0A6117120000059F46F0812A
      Acct Session ID:  0x000005C3
               Handle:  0x1F0005A0
Runnable methods list:
       Method   State
       dot1x    Authc Success
       mab      Not run
the vlan gets applied to the interface:
g23219ca18.es#sh int status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi1/0/1                      connected    10         a-full a-1000 10/100/1000BaseTX
Gi1/0/2                      notconnect   1            auto   auto 10/100/1000BaseTX
Gi1/0/3                      connected    10         a-full a-1000 10/100/1000BaseTX
but the ACL fails to be applied:
g23219ca18.es#sh ip access-lists interface gigabitEthernet 1/0/3
Which I suspect is becouse device tracking has failed to update.
g23219ca18.es#sh ip device tracking interface gigabitEthernet 1/0/3
IP Device Tracking Probe Delay Interval = 5
169.254.49.75   109a.dd54.0d3e  1    GigabitEthernet1/0/3     INACTIVE
132.234.113.96  109a.dd54.0d3e  1    GigabitEthernet1/0/3     INACTIVE
Total number interfaces enabled: 9
Enabled interfaces:
  Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/10,
  Gi1/0/12, Gi1/0/16
VLAN should be 10 and STATE should be ACTIVE
I added the delay of 5 to try and solve the issue ... the default is 0 which also does not work
Software is c2960s-universalk9-mz.150-2.SE2
Patrik did you get this solved?
Dale
Leo Laohoo
Your config is missing.
conf t
ip device tracking
int g 1/0/14
ip device tracking max 10
end
--- Wait for 31 seconds ---
Command:  sh ip device track all
config is all there....
g23219ca18.es#sh run | in device
ip device tracking probe delay 5
ip device tracking
g23219ca18.es#sh ip device tracking all
132.234.113.67  3c07.5446.cea5  10   GigabitEthernet1/0/1     ACTIVE
169.254.26.36   406c.8f1b.02ab  1    GigabitEthernet1/0/1     INACTIVE
132.234.113.110 406c.8f1b.02ab  1    GigabitEthernet1/0/1     INACTIVE
132.234.113.109 10dd.b1ab.29b1  1    GigabitEthernet1/0/10    INACTIVE
132.234.113.151 a820.665a.fb7a  1    GigabitEthernet1/0/7     INACTIVE
132.234.120.135 c82a.140d.bc1e  1    GigabitEthernet1/0/16    INACTIVE
132.234.120.139 406c.8f1b.02ab  1    GigabitEthernet1/0/1     INACTIVE
132.234.113.189 b8ca.3ad3.a9a9  10   GigabitEthernet1/0/6     ACTIVE
169.254.3.254   406c.8f1b.02ab  1    GigabitEthernet1/0/1     INACTIVE
132.234.136.39  406c.8f1b.02ab  1    GigabitEthernet1/0/1     INACTIVE
Enabled interfaces:
  Gi1/0/12, Gi1/0/16
g23219ca18.es#
I dont see the point in adding a maximum to the interface?
Thanks for your help
Dale
That's what we've done to all our interfaces.  And it works.
