IP DHCP Conflict in Catalyst 4500
ferly0001
Dear all,
I have a problem of dhcp conflict on my core switch cisco 4500 E.
Everyday i have found some of my IPPhone device get lost ip address, when i check in core that is so many ip dhcp conflict, so i type command clear ip dhcp conflict, after that my IPPhone can get IP address again. So everyday i should type that command. My range IP address is /23 and my IPPhone only 325 units.
Could you please give me the solution about this issue ? i attached the capture about the log and ios version
Thanks for your help
6 Replies 6
johnd2310
Level 8
Level 8
What is the lease period of your pool? Have you tried a smaller lease period?
John
**Please rate posts you find helpful**
Hi Mark,
Thanks for your comment, i will try from guide that suggestion at weekend
Hi Johnd2310,
The lease period is default 1 day, i didn't try to make smaller lease period. Do you have any recommended lease period ?
Mark Malone
follow this guide it should help
http://blog.ipspace.net/2007/08/dhcp-conflict-logging-true-story.html
Leo Laohoo
Hold on, this chassis is running on 3.3.0E????
I'd upgrade the firmware first.
Hi Leo,
running on 03.03.00.SG
3.6.6 would be a more stable version than 3.3 , some of the earlier version had a lot of bugs , that release is 2012
