Highlighted
Enthusiast
IP DHCP snooping bindings
I have DHCP snooping activated for vlan 11. I configured database agent on a remote TFTP server. DHCP bindings file is populated. However, a "show ip dhcp snooping binding" displays 0 entries.
is this normal behaviour, since bindings are written to the remote file?
Everyone's tags (2)
5 REPLIES 5
Highlighted
Beginner
Re: IP DHCP snooping bindings
You have true configure on the device for example IP DHCP SNOOPING have 7 step
Step 1 Enable DHCP snooping globally
Step 2 Enable DHCP snooping on your VLANs.
Step 3 Enable DHCP Option 82 data insertion.
Step 4 Configure the interface as trusted or untrusted <-------- very important
Step 5 Configure the number of DHCP packets per second (pps)
that an interface can receive.
Step 6 Exit configuration mode.
Step 7 Verify the configuration
thx
MA
Highlighted
Enthusiast
I already did all the steps you mentioned and still had the issue.
Highlighted
Frequent Contributor
Can you post your config first?
Highlighted
Beginner
configure terminal
ip dhcp snooping
ip dhcp snooping vlan vlan-range
ip dhcp snooping trustip dhcp snooping trust (Configure the interface as trusted or untrusted. You can use
the no keyword to configure an interface to receive messages from an
untrusted client. The default setting is untrusted)
ip dhcp snooping limit rate rate
ip dhcp snooping verify mac-address
end
show running-config
copy running-config startup-config
Switch(config)# ip dhcp snooping
Switch(config)# ip dhcp snooping vlan 10
Switch(config)# ip dhcp snooping information option
Switch(config)# interface gigabitethernet0/1
Switch(config-if)#ip dhcp snooping trustip dhcp snooping trust
Switch(config-if)# ip dhcp snooping limit rate 100
show ip dhcp snooping statistics
Thx
MA
Highlighted
Enthusiast
here it is:
TNSWACCS01A1#sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
11
DHCP snooping is operational on following VLANs:
11
Smartlog is configured on following VLANs:
none
Smartlog is operational on following VLANs:
none
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
   circuit-id default format: vlan-mod-port
   remote-id: 9caf.cac1.b280 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
FastEthernet1/0/1          no         no              50
  Custom circuit-ids:
FastEthernet1/0/2          no         no              50
  Custom circuit-ids:
FastEthernet1/0/3          no         no              50
  Custom circuit-ids:
FastEthernet1/0/4          no         no              50
  Custom circuit-ids:
FastEthernet1/0/5          no         no              50
  Custom circuit-ids:
FastEthernet1/0/6          no         no              50
  Custom circuit-ids:
FastEthernet1/0/7          no         no              50
  Custom circuit-ids:
FastEthernet1/0/8          no         no              50
  Custom circuit-ids:
FastEthernet1/0/9          no         no              50
add to that trunk interfaces that are trusted in DHCP snooping.
Content for Community-Ad
