09-07-2008 09:34 AM - edited 03-06-2019 01:13 AM
lab testing:
3825(w/16ESW)----3750(2stack)
Microsoft 2003 dhcp is hanging off the nm-16esw on 3825. The following is configured on 3750 BUT NOT ON THE 3825:
ip dhcp snoop
ip arp inspection
port security
ip source guard
dhcp trust is on the 3750 port-channel trunk. I believe dhcp snooping should work on this scenario but it is not.
so I turned off global dhcp snoop as well as took out the vlans on "ip arp inspection" and it works. How do I get dhcp snoop to work?
Thx
Solved! Go to Solution.
09-07-2008 03:18 PM
You probably need to disable option 82 insertion with 'no ip dhcp snooping information option' if your DHCP server doesn't support/use option 82.
09-07-2008 03:18 PM
09-07-2008 06:33 PM
Yes, that worked. Thanks
