ip helper redundancy
fd_case17
hi,
I need to implement this functionnality to be hsrp aware .
But the command is missing with my ios:
Could yuo confirm thus?
Thanx in advance.
Fab. D
6 Replies 6
Antonio Knox
Level 7
Level 7
To be certain of your issue, could you provide the command sequence that you are attempting (using private ip if necessary)?
Hi Fab,
Try below as from the best practice.
R3:
interface FastEthernet0/0
ip address 139.1.0.3 255.255.255.0
ip helper-address 139.1.13.1 redundancy HSRP
standby 1 ip 139.1.0.1
standby 1 preempt
standby 1 name HSRP
R6:
interface FastEthernet0/1
ip address 139.1.0.6 255.255.255.0
standby 1 priority 110
standby 1 preempt
standby 1 name HSRP
Please rate the helpfull posts.
Naidu.
thanx
the command is :
ip helper 1.1.1.1 redundancy CCNP
standby 1 name CCNP
The command is not implemented on the ios.
Did the command fail at the 'redundancy' keyword?  If not, where did it fail.
that's it
ip helper-address 1.1.1.1 ?
