08-27-2016 12:52 AM - edited 03-08-2019 07:10 AM
Gents,
I've a traditional 3-tier traditional design (not-Routed Access), in which I've Access layer containing the vlans, distribution layer having the SVIs serving as the gateways for those vlans configured on the Access nodes and the core layer connected to the distribution layer with OSPF backbone area.
Now on the access layer I've IPTV devices connected hence the require IP-Multicast to be enabled in the network.
Kindly, let me know what's the suitable multicast configs to be considered here in my scenario.
Thanking you all in advance!
Umer
08-27-2016 04:55 AM
Is IPTV source and destination connected to your access/distribution layer? if that is the case you would need IGMP at the access layer and PIM enabled on SVIs that need to have access to TVs on the distribution switches. If the source of IPTV is connected to the core than you need PIM on the core switches as well.
08-27-2016 05:02 AM
Thanks Dear Brother!
My IPTV end devices are connected to the Access switches, and IPTV servers are connected to the server farm switches those are directly connected to the Core nodes.
I've vlan 50 - 60 for the end devices and vlan 100-105 for the servers.
Between Core and Dist I've OSPF running.
Let me know what's an optimal solution here.
BR,
Umer
08-27-2016 08:05 AM
Ok, so if the server farm vlans terminate on the core switches than you would need to run PIM on the core as well. You probably want to make the core switches you RP.
Also, all 4 vlans SVIs need to have PIM enabled.
08-27-2016 08:17 AM
Thanks for prompt response bro!!
Let me know if the configuration of IGMP snooping querier is also required in the topology.
BR,
Umer
07-08-2017 02:34 AM
Hi Reza,
Do you have sample configs?
Kindly, let me know plz
