12-18-2017 07:52 PM - edited 03-08-2019 01:09 PM
I have 1 cisco 7945 ip phone can't get L2/L3 working when attached to 1 particular switch but it works on other switch. I just don get it why it won't work on that particular switch. Switch port config is correct.
What I noticed:
7945 phone MAC is not found in CAM table;
speed is a-100 but on other switch is a-1000;
12-18-2017 07:58 PM
What are the switch models? what is the switch pot config? What is the poe status on both switches?
John
12-18-2017 08:08 PM
12-18-2017 09:26 PM
Are the switches configured the same and is the software version the same? check that vlan 40 is working properly on the switch.
What is the error on the phone? is it stuck on "configuring IP" or "registering".
John
12-18-2017 10:06 PM
12-18-2017 09:49 PM
Is the phone getting a valid IP address or not?
12-18-2017 10:09 PM
12-18-2017 10:20 PM
Can you try factory-reset the phone?
12-18-2017 10:22 PM
