ip policy route-map does not working
csco11579831
I tried to apply the ip policy route-map command to an interface vlan X, but is not working.
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       15.0(2)SE1            C3750E-UNIVERSALK9-M
     2 30    WS-C3750X-24       15.0(2)SE1            C3750E-UNIVERSALK9-M
cadet alain
1° make sure you've got the IP services image installed on the master  with show licence
2° show sdm prefer and change your SDM template to  sdm prefer routing  if needed  then reload and verify with show sdm prefer again.
Alain
In addition to the good points that Alain makes I would ask that you provide some details of how you have configured Policy Based Routing. One common mistake is to apply the route map on the exit interface when that is required is to apply the route map on the interface on which traffic arrives. So if we can see what you have configured we can determine whether it is an issue like that.
Rick
Rick
csco11579831
Hi all,
HOSTKJ1#sh license
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: lanbase
HOSTKJ1#sh version
License Level: ipbase
Next reload license Level: ipbase
I only have a license IP base
how to proceed in order to obtain one ?
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
