Highlighted
Beginner
IP Policy route-map inside VRF Network.
Hi All,
I was trying to route one of the vlan internet traffic to Head office ASA, this vlan is inside VRF Network. Head office is connected through ISP VPN cloud. still the traffic is going through local ASA. Please advise.
interface Vlan100
description *** XXXXX ***
ip vrf forwarding ABC-VRF
ip address 10.X.X.X 255.255.255.0
ip policy route-map VLAN101-TEST
end
ip route vrf ABC-VRF 0.0.0.0 0.0.0.0 10.X.X.X 250 name INTERNET
ACL 100
Access-list 100 permit 10.X.X.X 0.0.0.255 any
route-map VLAN100-TEST:
route-map VLAN100-TEST permit 100
Match IP Address 100
Set ip next-hope X.X.X.X (VPN Gateway IP)
5 REPLIES 5
Highlighted
Hall of Fame Guru
What model of switch and what IOS version are you running ?
Jon
Highlighted
6509-E
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SXI4a, RELEASE SOFTWARE (fc2)
Highlighted
VIP Mentor
Hello
Does you ios support route-map command?
set ip vrf ABC-VRF next-hop xxxx
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Highlighted
Yes, it support this command.
I do not want to route entire vrf network to HO ASA, only one vlan internet traffic needs to route. Thanks.
Highlighted
You don't have to.
The acl used with the PBR configuration defines which traffic uses the PBR next hop. The command Paul provided is used by PBR but only traffic matching the acl will be sent to that next hop.
Jon
Content for Community-Ad
