IP Routing problem
darthgarlic
Community Member
I have a Cisco 2621 (172.30.1.50) attached to a network (172.30.1.0) the firewall is the gateway (172.30.1.1) and I cant ping anything in the real word by IP or by name. As the gateway and the Ethernet port are on the same network I dont think I need a routing statement in the Gateway/firewall. Can someone tell me what I am doing wrong?
version 12.2
hostname "Cisco-2621"
enable password cisco
ip subnet-zero
ip name-server 172.30.1.9
interface FastEthernet0/0
ip address 172.30.1.50 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/0
ip address 192.168.1.254 255.255.255.0
no cdp enable
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
no cdp enable
interface Serial0/1
ip address 192.168.3.254 255.255.255.0
no cdp enable
interface Serial0/2
no ip address
shutdown
no cdp enable
ip classlessno ip http server
no cdp run
line con 0
line aux 0
line vty 0 4
password cisco
login
end
Jennifer Halim
To reach the Internet, you would of course need to configure default gateway on the router, otherwise, the router wouldn't know where to route the traffic to.
To configure default gateway on the router, and you mention that firewall is the gateway to the Internet, you would need to configure the following:
ip route 0.0.0.0 0.0.0.0 172.30.1.1
Further to that, you would also need to check that the firewall is configured for NAT/PAT, access-list/policy to allow the traffic through towards the internet.
Jennifer Halim
Thanks Jennifer thats exactally what was wrong, newbie mistake.  Thank You
