IP SLA not working
benson.low
Hi CSC,
I have tried to implement IP SLA to monitor udp-jitter for voice packets, but it was not successful.
Configuration on R1
R1#show run | sec ip sla
ip sla 1
udp-jitter x.x.x.8 5000
ip sla schedule 1 life forever start-time now
ip sla 2
udp-jitter x.x.x.8 16384 codec g711alaw
ip sla schedule 2 life forever start-time now
SLA 1
Type of operation: udp-jitter
        Latest RTT: 39 milliseconds
Latest operation start time: 12:17:56 SIN Thu May 17 2012
Latest operation return code: OK
RTT Values:
        Number Of RTT: 10               RTT Min/Avg/Max: 38/39/40 milliseconds
Latency one-way time:
        Number of Latency one-way Samples: 0
        Source to Destination Latency one way Min/Avg/Max: 0/0/0 milliseconds
        Destination to Source Latency one way Min/Avg/Max: 0/0/0 milliseconds
Jitter Time:
        Number of SD Jitter Samples: 9
        Number of DS Jitter Samples: 9
        Source to Destination Jitter Min/Avg/Max: 0/1/1 milliseconds
        Destination to Source Jitter Min/Avg/Max: 0/1/1 milliseconds
Packet Loss Values:
        Loss Source to Destination: 0
        Source to Destination Loss Periods Number: 0
        Source to Destination Loss Period Length Min/Max: 0/0
        Source to Destination Inter Loss Period Length Min/Max: 0/0
        Loss Destination to Source: 0
        Destination to Source Loss Periods Number: 0
        Destination to Source Loss Period Length Min/Max: 0/0
        Destination to Source Inter Loss Period Length Min/Max: 0/0
        Out Of Sequence: 0      Tail Drop: 0
        Packet Late Arrival: 0  Packet Skipped: 0
Voice Score Values:
        Calculated Planning Impairment Factor (ICPIF): 0
        Mean Opinion Score (MOS): 0
Number of successes: 5
Number of failures: 0
Operation time to live: Forever
SLA 2
IPSLA operation id: 2
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: 12:19:46 SIN Thu May 17 2012
Latest operation return code: Timeout
RTT Values:
        Number Of RTT: 0                RTT Min/Avg/Max: 0/0/0 milliseconds
Jitter Time:
        Number of SD Jitter Samples: 0
        Number of DS Jitter Samples: 0
        Source to Destination Jitter Min/Avg/Max: 0/0/0 milliseconds
        Destination to Source Jitter Min/Avg/Max: 0/0/0 milliseconds
Packet Loss Values:
Voice Score Values:
Number of successes: 0
Number of failures: 16
R2#show ip sla responder
        General IP SLA Responder on Control port 1967
General IP SLA Responder is: Enabled
Number of control message received: 18 Number of errors: 0
Recent sources:
        x.x.x.8 [12:21:46.819 SIN Thu May 17 2012]
        x.x.x.8 [12:20:46.809 SIN Thu May 17 2012]
        x.x.x.8 [12:19:46.803 SIN Thu May 17 2012]
        x.x.x.8 [12:18:46.797 SIN Thu May 17 2012]
        x.x.x.8 [12:17:46.792 SIN Thu May 17 2012]
Recent error sources:
        Permanent Port IP SLA Responder
Permanent Port IP SLA Responder is: Enabled
udpEcho Responder:
  IP Address             Port
  x.x.x.x.8          16384
  x.x.x.x.8           5000
I have setup ip sla responder on R2, but it does not work. Any advice is appreciated. Thanks.
smehrnia
Level 11
Level 11
Try adding a frequency (second) under ur sla operation and run NTP on your SLA source and responder, because for UDP jitter to work properly time sync is important between src n rspnder.
if all those didnt help, try this form of sla command:
ip sla monitor 1
  type jitter dest-ipadd x.x.x.x dest-port xxxx
  frequency 10
ip sla monitor schedule 1 start-time now life forever
PLZ Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
Hi Soroush,
Thanks for the tips, i forget to mention that both routers are in sync with the same time server. I have tweak the frequency to 300 and I have already configured suggested jitter, and it is running fine for the suggested jitter, but not for the udp-jitter for voice traffic, but i am more concern on voip traffic and wish to get the statistics from voice score values:
My ios version is
Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
A quick check reveals that it is capable of doing the required ops, but i may be wrong.
that is exactly what you need to work. " jitter " is actualy same thing as UDP jitter and as far as i know that's what u need for voice. unless u explicitly state otherwise; like icmp-jitter.
> check this cisco doc on udp jitter:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6602/prod_white_paper0900aecd804fb392.pdf
Soroush.
Hope it Helps!
Soroush.
Hi Soroush,
Thanks, managed to find out the issue, i need to change my udp port. Guess that it might be in used. Take a look at voice score, it shows meaningful data now, whereas udp-jitter would not give such information.
vg1.sg0#show ip sla statistics 1
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
        Latest RTT: 40 milliseconds
Latest operation start time: 15:45:24 SIN Thu May 17 2012
RTT Values:
        Number Of RTT: 999              RTT Min/Avg/Max: 39/40/54 milliseconds
        Number of Latency one-way Samples: 999
        Source to Destination Latency one way Min/Avg/Max: 1/1/7 milliseconds
        Destination to Source Latency one way Min/Avg/Max: 37/38/47 milliseconds
Jitter Time:
        Number of SD Jitter Samples: 997
        Number of DS Jitter Samples: 998
        Source to Destination Jitter Min/Avg/Max: 0/1/5 milliseconds
        Destination to Source Jitter Min/Avg/Max: 0/1/9 milliseconds
Packet Loss Values:
        Loss Source to Destination: 1
        Source to Destination Loss Periods Number: 17
        Source to Destination Loss Period Length Min/Max: 1/32
        Source to Destination Inter Loss Period Length Min/Max: 6/32
Voice Score Values:
        Calculated Planning Impairment Factor (ICPIF): 1
        MOS score: 4.34
Number of successes: 2
Rgrds,
Benson
