IP SLA path-echo operation statistics multiple routes
tpol000011
Hello, guys
i've created a lab with 5 routers all running IOS 15.2
    ┌ ------- R3-----┐
   R1                   R4 ---- R5
    └--------R2-----┘
R1 has a two routes to R5:
through R2 is weight 10
through R3 is weight 20
i configured ip sla path-echo operation from R1 to R5
When all is up the packet goes R1-R2-R4-R5 and sh ip sla statistics aggregated shows all 3 hops with it's ip addresses
When i shutdown the fa1/0 on R1 with is connected to R2 the traceroute shows that packet now goes R1-R3-R4-R5 with is right too
The ip sla operation statistics also shows successes, but the hops addresses isn't changed
It still shows R1-R2-R4-R5
im a doing something wrong, or it is a bug/feature? :)
8 Replies 8
Antonio Knox
Level 7
Level 7
Post a sanitized config with just the relevant configs for review.
As this is a lab environment i will attach the configs themeselves
R1:
interface FastEthernet2/0
 ip address 172.16.10.1 255.255.255.0
 duplex half
interface FastEthernet3/0
 ip address 172.16.20.1 255.255.255.0
 duplex half
ip route 172.16.30.0 255.255.255.0 172.16.10.2
ip route 172.16.40.0 255.255.255.0 172.16.20.2
ip route 172.16.50.0 255.255.255.0 172.16.10.2 10
ip route 172.16.50.0 255.255.255.0 172.16.20.2 20
ip sla auto discovery
ip sla 10
 path-echo 172.16.50.1
 frequency 30
ip sla schedule 10 life forever start-time now
R2:
interface FastEthernet1/0
 ip address 172.16.10.2 255.255.255.0
 duplex half
 ip address 172.16.30.2 255.255.255.0
 duplex half
ip route 172.16.50.0 255.255.255.0 172.16.30.1
R3:
 ip address 172.16.20.2 255.255.255.0
 duplex half
 ip address 172.16.40.2 255.255.255.0
 duplex half
ip route 172.16.10.0 255.255.255.0 172.16.20.1
ip route 172.16.50.0 255.255.255.0 172.16.40.1
R4:
 ip address 172.16.30.1 255.255.255.0
 duplex half
 ip address 172.16.40.1 255.255.255.0
 duplex half
 ip address 172.16.50.2 255.255.255.0
 duplex half
ip route 172.16.10.0 255.255.255.0 172.16.30.2
ip route 172.16.20.0 255.255.255.0 172.16.40.2
R5:
 ip address 172.16.50.1 255.255.255.0
 duplex auto
 speed auto
ip route 172.16.10.0 255.255.255.0 172.16.50.2
ip route 172.16.20.0 255.255.255.0 172.16.50.2
Hello
It seems you have given the sla number to the primary route but not an admin distance
Try something like this:
ip route 172.16.50.0 255.255.255.0 172.16.10.2 track 10 150
ip route 172.16.50.0 255.255.255.0 172.16.20.2 200
ip sla 10
 imcp-echo 172.16.50.1 source-ip 172.16.10.2
 frequency 30
res
Paul
Kind Regards
Paul
ip route 172.16.50.0 255.255.255.0 172.16.10.2 10 150 - this gives me an error
after the "next hop" input i may input the route "distance"
i dont want to set the source-ip for the ip sla operation.
i want it to switch routes whr the primary interface goes down and it does! BUT, in the statistics the hops ip addresses stays the same as before. like it goes through primary route.
Hello
A track command
Kind Regards
Paul
and after the track i need to specify my ip sla operation index? or just a random number?
hello
On the primary router the Ip sla number then the admin distance -
On the secondary route just the admin distance which will need to higher than the primary route admin distance
res
Paul
Kind Regards
Paul
i assume that ip sla operation will fail if packets will go the second route, after i apply this change? am i correct?
