IP SLA Recurring
stephen.stack
Level 4
Level 4
Hi All,
I use an snmp tool to monitor IP SLA results. This works fine, but in testing this setup i noticed
that the Monitors i setup created a new collection index after the previous has completed. This happens
after 720 operations.
See config below
rtr 10
type echo protocol ipIcmpEcho 1.1.1.1 source-ipaddr 2.2.2.2
frequency 5
rtr schedule 10 life forever start-time now
ROUTER#sh rtr collection-statistics
Entry number: 10
Start Time Index: 19:08:19.628 GMT Thu Mar 11 2010
Number of successful operations: 720
Number of operations over threshold: 0
Number of failed operations due to a Disconnect: 0
Number of failed operations due to a Timeout: 0
Number of failed operations due to a Busy: 0
Number of failed operations due to a No Connection: 0
Number of failed operations due to an Internal Error: 0
Number of failed operations due to a Sequence Error: 0
Number of failed operations due to a Verify Error: 0
RTT Values:
RTTAvg: 2       RTTMin: 1       RTTMax: 216
NumOfRTT: 720   RTTSum: 1800    RTTSum2: 144548
Start Time Index: 20:08:19.628 GMT Thu Mar 11 2010
Number of successful operations: 201
RTT Values:
RTTAvg: 4       RTTMin: 1       RTTMax: 216
NumOfRTT: 201   RTTSum: 845     RTTSum2: 93617
Can anyone explain this to me? Is it important, and after each consecutive 720 operations is a new index created??
TIA
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Sergei Vasilenko
Hello Stephen,
By default the 2 backets of 1 hour stats are maintained for an IP SLAs operation.
In your case 720 x 5sec (freq) = 3600 sec.
You could also check this via CLI using "show ip sla monitor configuration ".
It could be changed however, please check the following:
Configuring and Scheduling an ICMP Echo Operation with Optional Parameters on the Source Device
http://www.cisco.com/en/US/partner/docs/ios/12_4/ip_sla/configuration/guide/hsicmp.html#wp1053262
Sergey
Sergei Vasilenko
Hello Stephen,
Sergey
Hi Sergey
Thanks for replying. So it appears that there will always be two buckets, and when the second finishes a new one starts and the old deletes or purges. Thats perfect.
Thanks for your help
Stephen
