%IPC-5-WATERMARK
Rojer-bkk
Hi Expert,
I got the logging error message about IPC below. I haven't ever seen before but checked CPU and memory is ok.
%IPC-5-WATERMARK: 2398 messages pending in rcv for the port Card5/1:Request(2150000.5) seat 2150000
Could it related to bug id CSCso14087? However, 6500 use 12.2(33)SRA4. Thanks in advance.
Edison Ortiz
You definitely have a process that is leaking and causing your TCAM/Memory Limits to exceed.
You may want to check the previous logs from any other warning.
You can reload the switch during maintenance and see if the error goes away and ideally update the code to a more recent one.
Since you are running 6500, I suggest running SXI train instead of SRA.
Hi Edison,
The error was gone after tried to reseat the card. Thank you.
Hi Rojer,
I got the similar error logs issue that logs every few minutes, but mine's is happening to Card22/0. May i know how you relate your Card5/1 to the physical interface/module? I couldn't relate my Card22/0 to which module from my system and i couldn't find any online document share about this information. Your information will be very helpful to me.
Nov 24 12:01:43 AEST: %IPC-SW1_STBY-5-WATERMARK: 6554 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3080000
