iPhone Connection
I have a home setup, pretty basic:
- Huawei VDSL modem
- Cisco 24 Managed switch
- Linksys LAPN300 Wireless-N300
I have several iOS devices that after a few hours will completely bottleneck on the download speeds.
I should be getting about 125mbps down, but suddenly I'm getting 1/100th of that. My upload speeds stay the same, but for some reason my download speeds get magically throttled.
Leo Laohoo
- Huawei VDSL modem
Is there a question somewhere?
I cant get the actual internet download speed from my iOS device not like any other devices
isn't that obvious ?
Apologies, I have not taken my mind-reading medication.
So what happens if the AP is turned off, does the download speed increase?
What is the speed with wired internet?
LAPN300 is only a 2.4 Ghz AP.  That is really not something I would be using even at home.
balaji.bandi
what is your ISP terms of delivery to the Internet - Definition Internet  ISP delivery most cases best effort basis,
Do you have any tools other than the above speed test?
First picture :
-  you are able to reach to that side 8ms latency with less jitter.
Second picture :
-  you are able to reach to that side 43ms latency with more jitter.
So this shows in the path there is high usage. (so you need to triage that issue? where is that issue?)
how about a computer connected to Wire network speed same time ?
Do you have any other tools to test other than the above speed test?
BB
