Ipv6 Again
alsayed
hello
Disabled Ipv6 on my 6509e720,but when i add any machine include Ipv6.the Brodcast come again..what can i do to stop that from the Core Switch.
10xs
6 Replies 6
royalblues
Level 10
Level 10
Ali,
IPv6 would be sending only multicast and no broadcasts. If any machine is configured for IPv6, they will send these multicast and the switch would mostly flood them.
Not sure if this will work but you can try denying the IPv6 packets on each port using an access-list
ipv6 access-list BLOCK deny ipv6 any any
interface x/y
ipv6 traffic-filter BLOCK in
Narayan
hello
can i appy these commands to interface Vlans
10xs
The reason to put the access-list on the port is to block the traffic entering the switch itself.
If it is applied on a interface vlan, the traffic would anyway be flooded on the vlan the incoming port was part of.
BTW, did you try this out in any one port?
Narayan
int gigabitEthernet 1/1
6509(config-if)#ipv6 traffic-filter blockin
% Invalid input detected at '^' marker.
look to this Output
sorry
6509(config-if)#ipv6 traffic-filter block in
any reply here
