IPV6 not working
pcfreak49
Hi I have a problem I'm trying to configure ipv6 but that would not work does anyone know how to do that?
John Blakley
What device are you working with? If it's a switch, you may have to change the sdm template, but if it's a router you'll need to enable it if the device supports it with "ipv6 unicast-routing".
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
I have a 800 series router and am trying to get the vlan and dhcp ipv4 from ipv6 to configure but that would not work well
