IPV6 Swtiching / Routing problem
I'm new to the community and I'm not sure if I'm asking in the right place. I'm also a total amateur but I've almost got the setup I need completed but now I'm stumped. Any help would be great.
I've got a Cisco router and switch. On the router, I have a tunnel out to an IPV6 tunnel broker service (This is working) I've got some bgp going on on my router as well. All of this for my own /32 of IPV6 addresses. I've got a trunked port out of my switch into my router, and a trunked port out of my switch off to a local host for vlan purposes.
I've got sub-interfaces on the router with the proper encapsulation and ID's set. I've got the vlans I need created on the swtich.
Over on my host machine, I try to connect out to the internet via my vlans and have no luck. I can utilize the block of address space I assigned to vlan 1 on the switch. Since vlan 1 is native all of that traffic heads over my hosts main interface. Say eth0. I can setup eth.1 , eth.2, etc and ping the switch address assigned to these vlans, as well as the gateway addresses assigned to the sub-interfaces on the router. But if I try to ping from one of the Vlans to something other than it's own subnet, I get nothing.
I'm not sure If I've explained it well enough...but I've been struggling for awhile and figured I'd ask. In case someone knows what I may be missing.
Thanks in advance!
The following document might help.
https://www.kernel.org/doc/Documentation/networking/vrf.txt
30 Replies 30
Hi Jason,
It looks like you might be missing the default gateway configuration on the host. Can you please attach the switch and router configuration.
Thanks so much for replying. I'll post my configs below...I'm a total amateur, so expect some nonsense. I haven't touched a router / switch from Cisco since 2003.
My router config:
Current configuration : 3212 bytes
! Last configuration change at 20:10:30 UTC Mon Sep 30 2019
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Cerberus
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password xxxxx
no aaa new-model
no ip domain lookup
no ip dhcp conflict logging
ip dhcp excluded-address 10.0.0.1
ipv6 unicast-routing
subscriber templating
license udi pid ISR4331/K9 sn FDO19321C50
redundancy
mode none
vlan internal allocation policy ascending
interface Loopback1
ip address 192.59.31.1 255.255.255.0
interface Tunnel0
description Hurricane Electric IPv6 Tunnel Broker
no ip address
ipv6 address 2001:472:1F0C:BF::2/64
ipv6 enable
tunnel source 216.115.150.175
tunnel mode ipv6ip
tunnel destination 208.51.163.34
interface GigabitEthernet0/0/0
ip address 216.115.150.175 255.255.255.192
ip nat outside
negotiation auto
ipv6 enable
interface GigabitEthernet0/0/0.1
encapsulation dot1Q 2
ip address 216.115.150.34 255.255.255.192
ip nat outside
interface GigabitEthernet0/0/1
ip address 10.0.0.1 255.255.255.0
ip nat inside
negotiation auto
ipv6 address 2602:fec2::1/35
ipv6 enable
ipv6 traffic-filter fromswitch in
ipv6 traffic-filter fromswitch out
interface GigabitEthernet0/0/1.2
ipv6 address 2602:fec2:2000::1/35
ipv6 enable
interface GigabitEthernet0/0/2
ip address 142.176.184.242 255.255.255.252
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
router bgp 397759
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 2001:472:1F0C:BF::1 remote-as 6939
neighbor 2001:472:1F0C:BF::1 update-source Tunnel0
address-family ipv4
exit-address-family
address-family ipv6
network 2602:fec2::/32
neighbor 2001:472:1F0C:BF::1 activate
exit-address-family
ip default-gateway 216.115.150.129
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip nat inside source static 10.0.0.24 216.115.150.34
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 216.115.150.129
ip access-list extended BaseACL
permit icmp any any
ip access-list extended Manage-SSH
ip access-list extended NOSPOOF
permit icmp any any
permit ip any any
ip access-list extended test
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.0.0 0.0.255.255
access-list 1 permit any
ipv6 route 2602:fec2::/32 Tunnel0
ipv6 route ::/0 Tunnel0
snmp-server community public RO
ipv6 access-list fromswitch
permit ipv6 any any
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 1 in
password virtew438fsa8AQ
login
line vty 5 15
access-class 1 in
login
end
My switch config:
Current configuration : 4700 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Cerberus
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx/
enable password xxxxxxxxxxxx
no aaa new-model
system mtu routing 1500
ip routing
ip dhcp pool LanPool
network 10.0.0.0 255.255.252.0
default-router 10.0.0.1
domain-name Cerberus.Local
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool PROXYSERVER
host 10.0.0.24 255.255.255.0
hardware-address e03f.49b1.a71e
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
shutdown
interface GigabitEthernet0/1
switchport trunk allowed vlan 1-8
switchport mode trunk
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
spanning-tree portfast trunk
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface TenGigabitEthernet0/1
interface TenGigabitEthernet0/2
interface Vlan1
ip address 10.0.0.11 255.255.255.248
ipv6 address 2602:fec2::2/35
ipv6 enable
interface Vlan2
no ip address
ipv6 address 2602:fec2:2000::2/35
ipv6 enable
no ipv6 nd nud igp
interface Vlan3
no ip address
ipv6 address 2602:fec2:4000::2/35
ipv6 enable
interface Vlan4
no ip address
ipv6 address 2602:fec2:6000::2/35
ipv6 enable
interface Vlan5
no ip address
ipv6 address 2602:fec2:8000::2/35
ipv6 enable
interface Vlan6
no ip address
ipv6 address 2602:fec2:A000::2/35
ipv6 enable
interface Vlan7
no ip address
ipv6 address 2602:fec2:C000::2/35
ipv6 enable
interface Vlan8
no ip address
ipv6 address 2602:fec2:E000::2/35
ipv6 enable
ip default-gateway 10.0.0.1
ip classless
ip default-network 10.0.0.0
ip route 10.0.0.0 255.0.0.0 10.0.0.1
ip http server
vstack
line con 0
exec-timeout 0 0
line vty 0 4
login
line vty 5 15
login
end
I've changed some of the public ip addresses to protect my poorly configured equipment a bit. So, the /35 configured on the main interface on the router has connectivity from my host out to the net. None of my vlan subnets can hit the net though.
Thanks again for the help.
Hi Jason,
I would highly recommend you change the /35 on the user subnets by /64.
Do you statically configure the IPv6 address and the gateway on the host?
Why did you configure a static route for the /32 pointing to the tunnel interface?
Can you please post a "show ipv6 route" from the router?
I can remove that route to the tunnel. It's not needed.
editing to answer a question I missed. Yes, I statically configure the gateway and address on the host.
On my first interface (vlan1) I use the following, and it works:
iface enp5s0 inet6 static
address 2602:fec2::3
netmask 64
gateway 2602:fec2::1
on vlan 2 I use this:
iface enp5s0.2 inet6 static
address 2602:fec2:2000::3
netmask 64
gateway 2602:fec2:2000::1
vlan-raw-device enp5s0
and it never gets past the router.
I did a sh ipv6 route local to exclude the tunnel interface. With bgp going on there are thousands of entries. If you have a different command that would exclude them and give you more detail I'll run it.
IPv6 Routing Table - default - 74145 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
B - BGP, R - RIP, I1 - ISIS L1, I2 - ISIS L2
IA - ISIS interarea, IS - ISIS summary, D - EIGRP, EX - EIGRP external
ND - ND Default, NDp - ND Prefix, DCE - Destination, NDr - Redirect
O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2, a - Application
L 2001:472:1F0C:BF::2/128 [0/0]
via Tunnel0, receive
L 2602:fec2::1/128 [0/0]
via GigabitEthernet0/0/1, receive
L 2602:fec2:2000::1/128 [0/0]
via GigabitEthernet0/0/1.2, receive
L FF00::/8 [0/0]
via Null0, receive
The output of show ipv6 route connected as well:
#sh ipv6 route connected
IPv6 Routing Table - default - 74134 entries
C 2001:472:1F0C:BF::/64 [0/0]
via Tunnel0, directly connected
C 2602:fec2::/35 [0/0]
via GigabitEthernet0/0/1, directly connected
C 2602:fec2:2000::/35 [0/0]
via GigabitEthernet0/0/1.2, directly connected
That's the output of sh ipv6 route local and connected. I'm new to ipv6. My intention was to have the /35 of addresses on the switch so that any host connected to that vlan can use any address in that 35 block. From the switch I'd like the traffic for each vlan (/35) to flow out through the routers subinterfaces and off to the Tunnel. Is that possible if I switch them over to /64?
I responded with the following previously and it was reported as spam by someone? If I'm doing something wrong by posting the following could you let me know?
netmask 64
netmask 64
L FF00::/8 [0/0]
via Null0, receive
Hi Jason,
I am not sure what happen, but I also saw your message had dissapeared.
I would strongly recommend to keep the prefix length the same on the server and on the router side. Otherwise, this could lead to various issues.
Can you please post the output from a "netstat -rn" from the server and the output from a "show vlan" from the switch.
Show Vlan Output from the switch:
VLAN Name Status Ports
1 default active Gi0/2, Gi0/3, Gi0/4, Gi0/5
Gi0/7, Gi0/8, Gi0/9, Gi0/10
Gi0/11, Gi0/12, Gi0/13, Gi0/14
Gi0/15, Gi0/16, Gi0/17, Gi0/18
Gi0/19, Gi0/20, Gi0/21, Gi0/22
Gi0/23, Gi0/24, Te0/1, Te0/2
2 VLAN0002 active
3 VLAN0003 active
1001 VLAN1001 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
1001 enet 101001 1500 - - - - - 0 0
2 VLAN0002 active
3 VLAN0003 active
Netstat -rn output:
netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 10.0.0.1 0.0.0.0 UG 0 0 0 enp5s0
10.0.0.0 0.0.0.0 255.255.255.0 U 0 0 0 enp5s0
I'm going to put the output of netstat -6 -rn as well:
Kernel IPv6 routing table
Destination Next Hop Flag Met Ref Use If
2602:fec2::/64 :: UA 256 0 1 enp5s0
2602:fec2::/35 :: UAe 256 0 0 enp5s0
2602:fec2:2000::/64 :: U 256 0 1 enp5s0.2
2602:fec2:4000::/64 :: U 256 0 1 enp5s0.3
fe80::/64 :: U 256 0 0 enp5s0
fe80::/64 :: U 256 0 0 enp5s0.2
fe80::/64 :: U 256 0 0 enp5s0.3
::/0 fe80::eebd:1dff:feb6:fce1 UGDAe 1024 2 4 enp5s0
::/0 fe80::224:98ff:feed:78c0 UGDAe 1024 0 0 enp5s0
::/0 :: !n -1 1 8 lo
::1/128 :: Un 0 5 26 lo
2602:fec2::3/128 :: Un 0 2 4 lo
2602:fec2::e23f:49ff:feb1:a81e/128 :: Un 0 1 0 lo
2602:fec2:2000::3/128 :: Un 0 1 0 lo
2602:fec2:4000::3/128 :: Un 0 1 0 lo
fe80::e23f:49ff:feb1:a81e/128 :: Un 0 1 0 lo
ff00::/8 :: U 256 1 2 enp5s0
ff00::/8 :: U 256 2 2 enp5s0.2
ff00::/8 :: U 256 1 1 enp5s0.3
That's everything. Thanks again for the help.
You should disable the "ipv6 unicast-routing" on the switch. The switch is currently configured as a router and is therefore sending router advertisement to the host and that is causing traffic to be blackholed. Can you do a "no ipv6 unicast-routing" on the switch and then try pinging a destination on the Internet again.
I've disabled ipv6 unicast on the switch. I can ping destinations on the internet from my primary interface, but vlan 2 is still a no go. Just shows as network unreachable. I'm not an expert but is it possible I need separate routing tables for each vlan on the host?
Seems the major issue is the default-gateway on the host is 2602:fec2::1 and no traffic from 2602:fec2:2000::3 will ever flow through there...or I'm mistaken. I know that in ipv4 multiple gateways could be specified but ipv6 doesn't seem to have that ability on my host.
I have another server that was setup in a similar fashion by an outside company. I haven't got access to their configs but everything seems to flow out over one gateway on that system. Just grasping at straws here.
Hi Jason,
I am glad this part works.
Could you please explain what it is exactly that you are trying to achieve with the various interfaces and the various subnets on the same server?
And could you please post the new output of a "netstat -rn" from the server.
Sure,
I have a /32 ipv6 block. I want a it broken into 8 /35 subnets. I want each /35 subnet assigned to a vlan. Vlans 1-8.
On this single server, I'd like to be able to access all 8 Vlans and have each vlan able to route out to the internet, via the tunnel on the router. So far, only Vlan 1, the native vlan, behaves the way I want.
I have other servers that will eventually be accessing them as well but for testing purposes I'd like them all accessible on the one server.
netstat -6 -rn:
2602:fec2::/64 :: U 256 0 1 enp5s0
::/0 2602:fec2::1 UG 1024 2 4 enp5s0
::1/128 :: Un 0 5 22 lo
2602:fec2::3/128 :: Un 0 2 2 lo
fe80::e23f:49ff:feb1:a81e/128 :: Un 0 2 5 lo
ff00::/8 :: U 256 0 0 enp5s0
ff00::/8 :: U 256 1 1 enp5s0.2
ff00::/8 :: U 256 0 0 enp5s0.3
Netstat -rn
Thanks again for all the help. I know it's a weird one but I had a similar setup on a previous server. I'm trying to get back to a similar setup on this network and the requirements I've outlined match up to what was on the previous network. Strange as it was.
It looks indeed like only one default gateway gets installed. Not sure if more than one could be installed on the server.
Could you please try adding the additional route manually using the following command:
/sbin/ip -family inet6 route add default via 2602:fec2:2000::1 dev enp5s0.2
Otherwise, it is certainly possible to implement one routing table per subinterface on the server. This might be the only option if it is not possible to install more than one gateway.
I gave it a go. Running the command produced "No route to host"  So I tried adding the route as a non-default and then adding it again as the default and got "file exists". So it looks like separate routing tables per vlan. Not sure how to go about that either. Do you have any idea what the routing table for interface vlan2 would look like? for in and out?
