IPV6 Traffic
alsayed
R1 & R3 are connected via F/R.configure ipv6 on both routers but the Ipv6 traffic doesn't traverse the frame-relay interfaces.configure ripng between these 2 routers
10xs
Harold Ritter
Ali,
Could you please post your configs.
Istvan_Rabai
Level 7
Level 7
Hi Ali,
Without seeing your config it is difficult to say what might the problem be, but I have one guess:
In the frame-relay map statements you should configure the link-local addresses of the neighbor routers, not the normal ipv6 addresses, like this:
frame-relay map ipv6 FE80::1 103 broadcast
You can find the autoconfigured link-local address of the serial interface of the neighbor router by using the "show ipv6 interface brief" command on the neighbor router.
You should apply this link-local address in the frame-relay mapping on the local router.
If this doesn't solve your issue, then please post your config.
Cheers:
Istvan
