Is it necessary to obtain a license for 9300L?
Mehdi Javadi
I currently have a 2960S switch and need a 9300L switch for my Lab.
Given that I am not planning to set up any routing protocol, do I need to obtain a license for 9300L to test the setup of a VLan between the 2960S and 9300 switches?
Thanks in Advance.
M02@rt37
Hello @Mehdi Javadi
No, you do not need to obtain a license for the C9300L to test VLAN configuration and basic Layer 2 switching between your 2960S and 9300L switches.
The default Network Essentials license that comes with the 9300L includes all the necessary Layer 2 features, such as VLAN creation, VLAN trunking, and STP. Since you are not planning to configure a routing protocol, you do not require the Network advantage license, which is needed for Layer 3 features like OSPF, EIGRP, and BGP.
VLANs operate at Layer 2, meaning as long as both switches support 802.1Q trunking, VLAN traffic can pass between them without requiring additional licensing.
Best regards
marce1000
 - You don't need a license for that
 M.
M02@rt37
Hello @Mehdi Javadi
Best regards
