06-11-2014 05:09 AM - edited 03-07-2019 07:42 PM
I have a hub and spoke topology. I also have a couple of switches connected to other switches and not home run back to the core. Can I simply run additional fiber from the "extended" switch back to another switch and trunk the ports?
06-11-2014 05:20 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Generally, the answer is yes. Also, if you're not running multiple VLANs, you don't even need to trunk. If you do have multiple VLANs, consider pruning.
For performance, if possible, avoid long daisy chains of switches; try to keep to a hierarchy.
Lastly, redundancy, i.e. using multiple paths, creates additional considerations for how you might want to interconnect switches.
06-11-2014 07:23 PM
Thanks Joseph.
