IS NET flow supported on 3650 and 3850 catalyst switch
ajay.anand1
Mark Malone
flexible netflow is supported not the older version,  I have it running on my ios-xe switches , 36s and 38s and nx-os switches works well
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/xe-3s/fnf-xe-3s-book/fnf-v9-export.html
Does Netflow affect CPU utilization on Cisco Switch 3850 if the Netflow is active continuously?
Will the Cisco 3850 become hang because of Netflow?
Thank you
No it won't cause any issues we have it running on all our switches and sending to two collectors without any issues
Tausif Gaddi
Comparison of Cisco Catalyst 3560-X and 3650 Switches
Feature
Cisco Catalyst 3650
Optional stacking
No
Yes (160 Gbps)
Native wireless controller support over Cisco IOS® Software
No
Yes
Support for Multigigabit speeds (1-, 2.5-, 5-, and 10-Gbps)
No
Yes*
Support for 60W Cisco Universal Power over Ethernet (UPOE) per port
No
Yes*
10GE uplinks
2 x 10 GE (field-replaceable unit [FRU])
8 x 10 GE/4 x 10 GE/2 x 10 GE (fixed) and 2 x 40G QSFP+ (fixed)*
Buffers per 48 port
6 MB
12 MB
Native flexible NetFlow support
No
Yes
Multicore CPU for hosted services
No
Yes
Quality of service (QoS) model and queues per port
MLS, 4 egress queues
MQC, 8 egress queues
Flash/DRAM size
64 MB/256 MB
2 GB/4 GB
External power system (XPS-2200)
Yes
No
Converged Access Solution
No
Yes
Operating system
Cisco IOS Software
Cisco IOS-XE Software
