10-13-2010 08:03 AM - edited 03-06-2019 01:29 PM
I am currently setting up a new office and we need a switch that has 10G interface for a test purpose. However we would also like to use the same switch for our office phone setup and would like to power the phones from the switch.
If not I will probably have to look at 2 different switches.
Thanks in advance for your help
Derek
10-13-2010 08:23 AM
Of course! Take a look at the Cat3750X, it has 24 or 48 10/100/1000 with POE+ or without. And it also has 1G or 10G uplink ports. Also, the Cat3750E, Cat3560X, and Cat3560E all have POE and 10G.
http://www.cisco.com/en/US/products/ps10745/prod_models_comparison.html
You can also look at the Cat4500 series, they are "modular" and you can add any types of ports that you need, including POE, non-POE, 10G. It all depends on how many ports you need, and how many phones.
Dan
10-13-2010 08:28 AM
I clicked submit to quickly, you can also use the "product advisor" at:
http://www.ciscowebtools.com/productadvisor/switches.asp
Dan
10-14-2010 01:40 AM
Hey Dan, thanks for the feedback, great links, I did some further digging on this myself and found the Cisco Catalyst 2960S-24PD-L which looks like it will fit also.
Thanks again for your help
Derek
