Is there any wccp restriction for SUP2T + VSS
adcampos
Hi Guys,
I'm working on a desing where I will use two CAT609-E each with a VS-SUP2T-10G.
and each chassis with the exact same number and type of WS-X68xx cards.
My customer requires among many things, wccp v2. His current solution is doing a L2 redirection to a WAE and GRE is not being used.
With the new hardware/Design he wants to enable VSS and I want to make sure wccp will continue to work without any restriccions.
Current wccp config on the existing CORE devices is:
ip wccp 61 redirect-list access-list-name
ip wccp 62 redirect-list access-list-name
SVIs for LAN
ip wccp 61 redirect in
SVIs for WAN
ip wccp 62 redirect in
and on WAE (4.4.1):
wccp router-list 1 IP-add-of-CORE IP-add-of-CORE2
wccp tcp-promiscuous service-pair 61 62 mask src-ip-mask 0xf dst-ip-mask 0x0
wccp tcp-promiscuous service-pair 61 62 failure-detection 30
wccp tcp-promiscuous service-pair 61 62 router-list-num 1 l2-redirect mask-assign
wccp version 2
so bottom line, is there any wccp restriccion with sup2t + +vss+ wccp?
Release note dont say anything about this combination.
Thank you!
0 Replies 0
