ISL only when enabling Q-in-Q and NAM monitor ports?
rlortiz
We were told that there is an issue (overlapping register usage) when you enable Q-in-Q and NAM Monitor ports and also use dot1q encapsulation that can cause traffic to stop flowing.
We had heard that you need to use ISL trunking instead of dot1q trunking for the service provider trunks.
We need to know whether or not we absolutely have to use ISL for the service provider trunking.
Can anyone verify and know of supporting documentation of this supposed restriction.
We've searched high & low and can't find anything to verify/support this.
The system environment is 6509s SUP720-3B 12.2(18)SXF and 12.2(33)SXI
NAM-2 running 4.0(1)
Giuseppe Larosa
Hello Richard,
not sure about NAM.
for 802.1 Q in Q on the service provider side you can force tagging of native vlan.
the only reason to use ISL in this context is that missing the native vlan concept you avoid the risk to expose the inner customer vlan tag.
forcing native vlan tagging allows to use 802.1Q external tags without this risk.
I would look at 12.2(33)SXI relase notes for suggestions.
you can find it (huge wen page..)
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html
I've found
CSCsu75546
but it is about span to NAM from port channel
CSCsv75511 applies to a NAM in standby chassis in a VSS pair
CSCsq85139 again in VSS
CSCso46210 again in VSS
CSCsk81396 : very important possible crash in 12.2(18)SXf
fixed in 12.2(18)SXF12
this has to be verified
CSCsk24272: as the one above to be verified fixed in 12.2(18)SXF12
CSCsd75273: cisco NAM vulnerability
solved in 12.2(18)SXF5
CSCse52951: as the one above
CSCsi11382: diag failures of NAM
solved in 12.2(33)SXH
I don't see a known bug related to QinQ and NAM module
Hope to help
Giuseppe
