02-05-2013 06:44 PM - edited 03-07-2019 11:32 AM
Hi everybody
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094665.shtml
According to this link, ISL uses 40 bit multicast mac addresses shown below:
The DA field of the ISL packet is a 40-bit destination address. This address is a multicast address and is set at "0x01-00-0C-00-00" or "0x03-00-0c-00-00". The first 40 bits of the DA field signal the receiver that the packet is in ISL format.
1)Mac address consists of 48 bits, so what does switch use for the last 8 bits in ISL destination mac ?
2) How does switch determine which destination mac multicast address to use in ISL as we have two option i.e "0x01-00-0C-00-00 and 0x03-00-0c-00-00".?
thanks and have a great day.
Solved! Go to Solution.
02-06-2013 12:41 AM
Hello Sarah,
the use of a multicast MAC address on ISL trunks was likely thought because ISL by design can accomodate multipoint to multipoint trunk ports like having multiple LAN switches connected with an hub in the middle. But that would mean half duplex operation in a single collision domain.
Clearly all real world trunks are point to point and full duplex making this ISL feature useless.
My personal guess is that the exact value of the less significant 8 bits are don't care, that is they can have any value and the ISL peer device will process the frames.
Between 0x01-00-0c-00-00-xx and 0x03-00-0c-00-00-xx there is only a slight difference of second bit set in most meaningful octect.
They are both multicast MAC address and the bit set means local meaning.
As explained in the link below, the less significant bit of most significant octect is the I/G individual/group address and means multicast when set (or broadcast). The near bit stays for universal or local meaning of the MAC addres
see
Hope to help
Giuseppe
02-06-2013 01:34 PM
02-06-2013 12:41 AM
Hello Sarah,
see
Hope to help
Giuseppe
02-06-2013 07:11 AM
Thanks Giuseppe.
Just brushing up on some switch topics, I am taking my last exam Tshoot on next mon. Hopefully I will pass it first time unlike Route and switch exams which I have failed once.
Nice to hear from you after a while.
Have a great day.
02-06-2013 01:34 PM
Hi Sarah,
Good luck with Tshoot exam.
Mahesh
02-06-2013 03:29 PM
Thanks Mahesh
02-07-2013 12:39 AM
Hello Sarah,
good luck for your exam.
Have you checked the cisco learning network ?
We are all happy to see your progress.
Best Regards
Giuseppe
02-07-2013 06:53 AM
Hi Giuseppe.
Yes, I did. Luckily Cisco put the topology diagram on its web site for CCNP Tshoot. It saves a lot of time that could otherwise be wasted understanding the topology.
Once I get this exam done, plan is to actively participate on this forum answering questions by researching the question first.
Thanks for your kind words.
Have a great day.
