Isolate VLAN X from other VLANS
ralpho1
Hello Together,
we have a Catalyst 9500 Core Switch and I wan to Isolate a specified VLAN (VLAN 5) deny to connect to all other VLAN. Here is a simple configuration and explanation what the result should be.
VLAN 2 (Server) 10.1.2.0/24 Gateway VLAN interface 10.1.2.1
VLAN 3 (Client) 10.1.3.0/24 Gateway VLAN interface 10.1.3.1
VLAN 4 (Production) 10.1.4.0/24 Gateway VLAN interface 10.1.4.1
VLAN 5 (Development) 10.1.4.0/24 Gatway VLAN interface 10.1.4.1
VLAN 6 (Transfer VLAN to Firewall) 10.1.6.0/30 Gateway 10.1.6.1
and so on.
Now VLAN 5 (Development) should not be able to communicate with all other VLAN´s (2 -4, 6 >) and should only have Access to the Internet. There is a Firewall as next Hop (VLAN 6) to Internet and we have Configured Cisco ISE for 802.1x for security.
VLAN 5 needs, NTP, DHCP, HTTPS for the first.
I tried to use Named extended ACL on the 9500 on VLAN interface 5 but I can´t get a satisfied Result.
I saw some other threads here but these are do not help me. Maybe do I have to go an other way as ACL?
Many Thanks and Regards
Ralph
Enes Simnica
gDay @ralpho1 Yes, you can isolate VLAN 5 using an ACL, u just need to allow the specific services it needs, block all internal subnets, and then permit everything else toward the firewall for Internet access. Also, VLAN 4 and VLAN 5 can’t both use 10.1.4.0/24, so fix that first (use these commands, also forgive me if i type something wrong, typing this as I eat lunch HAHA LOOLx2):
ip access-list extended VLAN5_OUT
  permit udp any host <dhcp_server> eq bootps
  permit udp any host <ntp_server> eq ntp
  permit tcp any host <ise_IP> eq 443
  deny ip any 10.0.0.0 0.255.255.255
  deny ip any 172.16.0.0 0.15.255.255
  deny ip any 192.168.0.0 0.0.255.255
  permit ip any any
and also this one for the end: int vlan 5  : ip access-gr vlan5 out
hope it helps and PEACE!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Hi Enes, many thanks this sound´s good too me. oh, I see the mistake with VLAN 5, I read two times but on configuration site is right. I will give it a try and respond here,
best Regards Ralph
Joseph W. Doherty
Another option you might consider is placing VLAN 5 into a separate VRF, which would also allow the VLANs 4 and 5 use the same /24, but your requirements accessing the Internet and other (shared?) services probably makes using a VRF additionally complex vs. just using ACLs for no real benefit.
ralpho1
Joseph, I will follow your advice. Thanks to all for your Ideas
