ISR 2921
Docklands
Can the ISR 2921 router onboard WAN ports and SFP be used to terminate a VLAN trunk using
encapsulation dot1q
Reza Sharifi
Yes, if you use a sub-interface you can use dot1q.
config t
inter gi0/0.20
encapsulation dot1Q 20
ip address....
inter gi0/0.30
encapsulation dot1Q 30
ip address....
Reza Sharifi
config t
inter gi0/0.20
ip address....
inter gi0/0.30
ip address....
Docklands
Thank you Reza
