isr 4321 accidental reboot
Have an ISR 4321. IOS xe version isr4300-universalk9.16.06.06.SPA.bin
Router reboots Several times a day. Console output at the moment of reboot:
*Jun  5 12:46:20.680: %CPPHA-3-FAILURE:  SIP0: cpp_ha_top_level_server:  CPP 0 failure Stuck Thread(s) detected
*Jun  5 12:46:20.680: %CPPHA-3-FAULT:  SIP0: cpp_ha_top_level_server:  CPP:0.0 desc:Stuck  CPP Thread det:HA class:OTHER sev:FATAL id:0 cppstate:STOPPED res:UNKNOWN flags:0x2 cdmflags:0x0
*Jun  5 12:46:20.680: %CPPHA-3-FAULTCRASH:  SIP0: cpp_ha_top_level_server:  CPP 0.0 unresolved fault detected, initiating crash dump.
*Jun  5 12:46:20.682: %IOSXE-1-PLATFORM:  SIP0: kernel: QFP0.0: Fatal Fault: SW reported: Ucode process fault
*Jun  5 12:46:20.698: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Jun  5 12:46:20.685: %CPPHA-3-CDMDONE:  SIP0: cpp_ha_top_level_server:  CPP 0 microcode crashdump creation completed.
*Jun  5 12:46:20.690: %IOSXE-6-PLATFORM:  SIP0: cpp_ha_top_level_server: Shutting down CPP MDM while client(s) still connected
*Jun  5 12:46:20.701: %IOSXE-1-PLATFORM:  SIP0: kernel: QFP0.0: Fatal Fault: SW reported: Ucode process faultQFP0.0: Fatal Fault: SW reported: Ucode process fault
*Jun  5 12:46:20.762: %IOSXE-3-PLATFORM:  SIP0: Jun  5 12:46:20 pman.sh: %PMAN-3-PROCHOLDDOWN: The process cpp_ha_top_level_server has been helddown (rc 69)
*Jun  5 12:46:20.785: %CPPDRV-3-LOCKDOWN:  SIP0: cpp_cp_svr:  QFP0.0 CPP Driver LOCKDOWN encountered due to previous fatal error (SW: Ucode proces
Flash is full of kernel.rp-RP* files.
Jun  5 12:50:14.717 RP0/0: %FLASH_CHECK-3-DISK_QUOTA: Flash disk quota exceeded [free space is 410324 kB] - Please clean up files on bootflash.
isr4321#sh flash: | inc kernel
1110      75317 May 31 2019 06:43:10.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531064310.txt
1111      49088 Jun 03 2019 17:07:54.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603170754.txt
1112  199933952 May 30 2019 09:37:54.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0.core.TEMP_IN_PROGRESS.
1113      74934 May 31 2019 06:58:22.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531065822.txt
1115   95258966 May 31 2019 06:58:49.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531065822.core.flat.gz
1117      60474 May 31 2019 07:30:16.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531073016.txt
1118   53989516 May 31 2019 07:30:36.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531073016.core.flat.gz
1119      77743 May 31 2019 07:26:36.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531072636.txt
1120   68392143 May 31 2019 07:27:00.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531072636.core.flat.gz
1121      74878 May 31 2019 07:50:56.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531075056.txt
1122   98628944 May 31 2019 07:51:24.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531075056.core.flat.gz
1123      49352 May 31 2019 07:54:01.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190531075401.txt
1124     442677 Jun 03 2019 14:19:52.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603141952.txt
1125      75347 Jun 03 2019 13:15:52.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603131552.txt
1127   89188522 Jun 03 2019 13:16:19.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603131552.core.flat.gz
1128          0 Jun 03 2019 14:20:34.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603141952.txt
1130      80255 Jun 03 2019 15:16:10.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603151610.txt
1132          0 Jun 03 2019 15:16:33.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603151610.txt
1133      77114 Jun 03 2019 16:04:07.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603160407.txt
1134          0 Jun 03 2019 16:04:35.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603160407.txt
1135      77727 Jun 03 2019 16:35:08.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603163508.txt
1137          0 Jun 03 2019 16:35:25.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603163508.txt
1138      77921 Jun 03 2019 16:47:31.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603164731.txt
1139          0 Jun 03 2019 16:47:48.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603164731.txt
1140     101465 Jun 03 2019 17:05:11.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603170511.txt
1141          0 Jun 03 2019 17:05:24.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603170511.txt
1142   40988748 Jun 03 2019 17:08:06.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603170754.core.flat.gz
1143      78453 Jun 03 2019 18:01:05.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603180105.txt
1144          0 Jun 03 2019 18:01:15.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603180105.txt
1145     338466 Jun 03 2019 18:36:43.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603183643.txt
1146          0 Jun 03 2019 18:36:57.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603183643.txt
1147     451457 Jun 03 2019 19:03:44.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603190344.txt
1148          0 Jun 03 2019 19:04:00.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603190344.txt
1149     358366 Jun 03 2019 20:06:01.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603200601.txt
1150          0 Jun 03 2019 20:06:16.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603200601.txt
1151      77178 Jun 03 2019 20:35:27.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603203527.txt
1152          0 Jun 03 2019 20:35:36.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603203527.txt
1153      76779 Jun 03 2019 21:00:11.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603210011.txt
1154          0 Jun 03 2019 21:00:20.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603210011.txt
1155      76956 Jun 03 2019 22:09:11.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603220911.txt
1157          0 Jun 03 2019 22:09:20.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603220911.txt
1158      76834 Jun 03 2019 22:20:40.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603222040.txt
1159          0 Jun 03 2019 22:20:49.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_NO_SPACE_20190603222040.txt
1160      81633 Jun 03 2019 23:08:19.0000000000 +00:00 /bootflash/core/kernel.rp_RP-ISR4300_0_20190603230819.txt
Cisco states that autogenerated files on the bootflash: directory should not be deleted, renamed, moved, or altered
The question is what's going on with the box.
Mark Malone
Looks like a bug , just put this in google you'll see all the bug IDs effecting ios-xe releases
I would upgrade , you could TAC it either get the exact bug id or check the release notes of your image to see if the caveat is there
