ISR4331-3x1GE - interface down line protocol down
USAUB-LR-02(config-if)#do sh int gig 0/0/2
GigabitEthernet0/0/2 is down, line protocol is down
Hardware is ISR4331-3x1GE, address is 009a.d287.bea2 (bia 009a.d287.bea2)
Description: Public Internet
MTU 1500 bytes, BW 10000 Kbit/sec, RxBW 50000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is T
output flow-control is on, input flow-control is on
Last input never, output never, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
#sh run int gig0/0/2
Building configuration...
Current configuration : 311 bytes
interface GigabitEthernet0/0/2
description Public Internet
bandwidth 10000
bandwidth receive 50000
ip vrf forwarding wan
ip address XX.XX.170.67 255.255.255.248
no ip redirects
no ip proxy-arp
ip access-group public-wan-filter in
negotiation auto
no cdp enable
service-policy output SHAPE_10M
end
Troubleshooting steps taken:
1.User has another device with the matching hardware as well as software and SFP is working fine on another router
2.moved working sfp to this router, it stops working on this device
3.cable has been swapped.
4.changed the remote end to a different port and port still not coming up
5.default interface on both ends. still no go.
6.removed the vrf configuration and tried again. no go
7.Asked the user to connect the devices back to back. no go
8.verified that the code is compatible with the SFP - GLC-TE.
9.checked the duplex and speed settings, which are configured fine.
10.Replaced SFP on the port, still facing the same issue
11. Device has been RMAed and still the same issue persists.
Pleae assist/advise
6 Replies 6
check if you might be running into this issue:
http://www.cisco.com/c/en/us/support/docs/field-notices/642/fn64253.html
Hey Georg,
Thanks for the quick response!!
We had the device RMAed, and still facing the same issue with the new device.
The RMAed device might still have the affected serial number, can you check that ?
The RMAed device also belongs to the one in the Field Notice. I called cisco for a TAC case they say it is not under warranty or contract. let me try contacting the team in the FN.
Sandeep Verma
Hi , Did this issue get resolved anyhow ?
Sandeep
looking at the docs you need to be on a specific or higher ios-xe version for LH sfps
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
