isr4351 interface speed
Mary
the default isr4351 interface is 1000Mb, how to hardcode to 100M, speed command not working
Reza Sharifi
If it is a copper port, it usually auto detects it when you connect a 100 Mb device to it.
Yes, all ports in question here are copper.
Should I be specifying the bandwidth on all the ports, and force 300Mbps through all interfaces ?
