ISSU loadversion initialized on RPR mode
avm_veera
Visitor
I have used ISSU for 6509 VSS to upgrade the IOS From s72033-adventerprise_wan-vz.122-33.SXI5.bin,12 to s72033-adventerprisek9_wan-vz.122-33.SXI5.bin,12; version
I have referred below link for ISSU
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/issu_efsu.html#wpxref41569
As per the document there will not be any network outage if we do ISSU for the IOS ver SXI.  The upgrade was success, but I got a network outage of 5 min...Please let me know why it took 5 min Network outage.
Below are the steps followed:-
1)      The command issu loadversion sup-bootdisk:s72033-adventerprisek9_wan-vz.122-33.SXI5.bin reload the standby Sup and booted with the new IOS but the Standby sup becomes STANDBY COLD and the redundancy mode becomes RPR mode.
O/P’s as below
CORE#sh issu state
Slot = 1/5
RP State = Active
ISSU State = Load Version
Boot Variable = bootdisk:s72033-adventerprise_wan-vz.122-33.SXI5.bin,12
% Standby information is not available because it is in 'DISABLED' state
CORE#sh issu state
Slot = 1/5
RP State = Active
CORE#sh issu state
Slot = 1/5
RP State = Active
Slot = 2/5
RP State = Standby
Boot Variable = bootdisk:s72033-adventerprisek9_wan-vz.122-33.SXI5.bin,12;bootdisk:s72033-adventerprise_wan-vz.122-33.SXI5.bin,12
CORE#sh redundancy
Redundant System Information :
Available system uptime = 1 week, 6 days, 5 hours, 30 minutes
Switchovers system experienced = 4
Standby failures = 1
Last switchover reason = active unit removed
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = rpr Reason: Software mismat
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 1/5
Current Software state = ACTIVE
Uptime in current state = 1 week, 5 days, 18 hours, 23 minutes
Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISE_WAN-VM), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 03:26 by prod_rel_team
BOOT = sup-bootdisk:s72033-adventerprise_wan-vz.122-33.SXI5.bin,1;
CONFIG_FILE =
BOOTLDR =
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 2/5
Current Software state = STANDBY COLD
Uptime in current state = 2 minutes
Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-VM), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Compiled Sat 23-Oct-10 07:23 by prod_rel_team
CONFIG_FILE =
BOOTLDR =
2)      The command issu runversion , initialized the standby sup to Active but it took 5 min to make the standby SUP to Active.
3)      Then completed the upgrade with the commands ISSU acceptversion and ISSU commitversion.
Please let me know why the Standby SUP initialized on RPR mode instead of SSO.
Yogesh Ramdoss
ISSU from non-crypto to crypto image will fail eFSU/ISSU compatability check.
Reference document:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/issu_efsu.html#wp1116940
Please note the limitation:
"Images from different features sets, regardless of release, fail the eFSU compatibility check"
eFSU/ISSU fails even when we migrate from modular to non-modular IOS (or vice versa)
Hope this helps.
- Yogesh
