09-24-2011 12:20 PM - edited 03-07-2019 02:25 AM
Hello
I have recently updated our 3750g-24PS switches they are now running
12.2(58)SE2 with C3750-IPSERVICESK9-M
The switches are working BUT
the leds over each of the ports are flashing much more that before. They are not a steady flash, but seems to start and stop with some random cycle.
Thery do this even when swictjing between modes using the front panel button
before i contact TAC. has anyone else seen this?
should i d/l back to the old version or some other new version
any advise would be usefull
walter
09-24-2011 12:38 PM
Hi Walter,
Are you noticing any issues with respect to the switch's operation (high cpu or forwarding latency etc) ?
Kapil
09-24-2011 01:01 PM
This usually occur if there is some loop or high cpu..Following outputs will help-
sh proc cpu sorted (when the LEDs flash)
sh proc cpu history
09-24-2011 04:47 PM
Is your switch the ones that come with 16mb of flash?
09-25-2011 09:18 AM
Hello:
Thank you all for the responses so far
I do not notice any switch operation issues
The CPU traces below seem to show a busy switch over the long term ,
but short term shows negligble work (;
Devices are not showing any drops or delays. though the front panel lighhts are worrying me as the previous IOS c3750-advipservicesk9-tar.122-46.SE was OK
here are a few details from the switch
Directory of flash:/
32514048 bytes total (12913664 bytes free)
cisco WS-C3750G-24PS (PowerPC405) processor (revision F0)
with 131072K bytes of memory.
866666555556666644444555555555566666555556666655555666666666
100
90
80
70
60
50
40
30
20
10 **************** *************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
667667677777776777877767667777777787787877777778787878788886
100
90
80
70
60 *
50 *
40 *
30 *
20 *
10 ##########################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
362536253563447352534355555444646374544644252535463535444455446547455344
425035909959628407258924211954405679536325797243483372245680540631975265
100
90
80 * *
70 * * * * * * *
60 * * ** * * * * * * * * * ** * **
50 * * * * ** * * * * * ******* * * *** ** * * * * * * * ***** ** ****
40 * * * ******** * ************************ * * *** ******************
30 **********************************************************************
20 **********************************************************************
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
