Jumbo Frame config help on 4506
jforbis
Beginner
Beginner
Hello.. I have a 4506 with a SUPIII card and a WS-X4448-GB card. I want to enable jumbo frames for a iscsi connection. When I go into the interface that I want to enable jumbo frames on I issue the command:
mtu 9192. I then get the error "% Interface GigabitEthernet2/48 does not support user settable mtu."
Does anyone know how I can get around this?
Thanks!
James
Jon Marshall
James
As far as i know you can't because this module does not support jumbo frames. See this link for list of modules that do -
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/sw_int.html#wp1068699
Jon
