Jumbo frames and flow control
crendall
I have an iSCSI SAN and it supports Jumbo frames and flow control. My current switch support Jumbo frames and flow control, just not at the same time. I'm wonder if Cisco has a 24-port gig switch that supports Jumbo frams and flow control at the same time.
smalkeric
Level 6
Level 6
Following document provides a sample configuration for Maximum Transmission Unit (MTU) sizes supported across all of the Cisco Catalyst-series switches on Ethernet-based ports.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
Thanks for the link to adjust the MTU. My question is does the 2960 support Jumbo frames and flow control at the same time? My current HP switch does not and I'd like to replace it with something that does.
Thanks.
