jumbo frames on 10gb sfp+ uplink and cross-stack etherchannel
vince.steiner
I have a pair of stacked 2960S with 24 gig ports each, 2 sfp+ 10gb ports (uplinks), 2 cross-stack etherchannels and 2 vlans.
so if i issue "system mtu jumbo 9198" command and reload i understand that all 48 gig ports in a stack will be enabled for jumbo frames,
but what about these 2 10gb sfp+ uplinks, cross stack ether-channels, vlans?
do i need to issue a separate mtu comand on the int level for 10gb uplinks?
btw, the cross-stack etherchannel is only between 1gb ports, not 10gb.
thanks
Hello Gregory,
system means system wide, so it will apply to all interfaces regardless of their speed, higher end switches (C6500) allow to set MTU per interface, but it is not the case for these 2960
I would suggest to do the change during a maintanance window and to check the effects on the etherchannel.
Hope to help
Giuseppe
vince.steiner
any ideas?
Hello Gregory,
Hope to help
Giuseppe
