JumboFrames on cisco3750g for iSCSI traffic
e2andreas
Hello Communality,
I need you help!
here is the goal: connect SAN and vmware ESXi by iSCSI via cisco3750g.
on cisco I'm using a separated vlan for iSCSI traffic.
So after turning on the JumboFrames on cisco ( system mtu jumbo 9000 > reload) I was trying to test it using PING command from the switch without success :-(
#show system mtu
System MTU size is 1500 bytes
System Jumbo MTU size is 9000 bytes
System Alternate MTU size is 1500 bytes
Routing MTU size is 1500 bytes
#ping 192.168.0.21 size 9000 df-bit repeat 1
Sending 1, 9000-byte ICMP Echos to 192.168.0.21, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 0 percent (0/1)
#show int gi1/0/3 mtu
Port      Name               MTU
Gi1/0/3   iSCSI              9000
#show vlan mtu
VLAN    SVI_MTU    MinMTU(port)      MaxMTU(port)     MTU_Mismatch
1    1500          9000              9000              No
192   1500          9000              9000              No
#show ru int gi1/0/3
Building configuration...
Current configuration : 108 bytes
interface GigabitEthernet1/0/3
 description iSCSI
 switchport access vlan192
 switchport mode access
end
thanks!
5 Replies 5
Hello
Did you reload the switch?
res
Paul
Kind Regards
Paul
sure! I did reload the switch after MTU set to 9000
Hello
Does the interface need to be an access port or trunk?
res
Paul
Kind Regards
Paul
it's only an access port
rsblind01
Did you ever find the answer to this question?
RS
