Keeping hostnames
TroyBolton
I am currently doing a switch upgrade from a 4K to a 9K, the 4K is currently live, it's a straight swap so the config on the 4K have just been copied onto the 9K, my question is how do i keep the host-names the same on the 9K? would i just take down the 4K and then have the 9K's plugged in(assuming i have configured the switch to have the same host name?) or do i use a separate host-name and then when the new 9K is live change the hostname?
Also would have any ideas on an implementation plan?
Mark Elsen
 - Keeping host names is not advisable. New names have benefit to avoid confusing for ICT-staff (service desk -e.g.) and asset-management.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Cristian Matei
    Since these two devices will not be in the network, connected, at the same time (have the same config and one is a replacement for the other), you should just keep the same name. As a second point of view, most customers have naming convention of their devices, which is kept unless otherwise instructed; so you should keep the name.
Cristian Matei.
