Known issues (bug)on GNS3 ??
solemdoms5
When I put "clear ip ospf process" after changing router-id on GNS3 , I got the bug
that there was the output of "show ip ospf neighbor" but there was no ospf route . like following output
after that , again I did put " clear ip ospf process "  without any changes after 2 minutes  .
I could see the output of " sh ip route ospf " .
Is this known bug on GNS3 ? Or
Is this the known issue that it happens sometime on real Cisco routers ?
I dont have the real labo . so I feel so insecure .
Here is the output after did put " clear ip ospf process "
R3#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
1.1.1.1           1   FULL/DR         00:01:42    172.16.100.1    Serial0/0     <------------------------------------- I can see the neighboring
R3#
R3#sh ip route ospf
      <--------------------------------------------------there is no route .
R3#clear ip ospf pro  <-------------------------again I put clear ip ospf process
Reset ALL OSPF processes? [no]: y
R3#
*Mar  1 00:22:44.903: %OSPF-5-ADJCHG: Process 1, Nbr 1.1.1.1 on Serial0/0 from FULL to DOWN, Neighbor Down: Interface down or detached
R3#
*Mar  1 00:23:08.359: %OSPF-5-ADJCHG: Process 1, Nbr 1.1.1.1 on Serial0/0 from LOADING to FULL, Loading Done
R3#
R3#sh ip ospf nei
1.1.1.1           1   FULL/DR         00:01:50    172.16.100.1    Serial0/0
R3#
R3#sh ip route ospf                                        <-------------------------------------This time I can see the output of sh ip route ospf
     172.16.0.0/16 is variably subnetted, 10 subnets, 4 masks
O       172.16.255.2/32 [110/65] via 172.16.100.2, 00:00:24, Serial0/0
O       172.16.255.1/32 [110/65] via 172.16.100.1, 00:00:24, Serial0/0
O IA    172.16.255.5/32 [110/75] via 172.16.100.2, 00:00:24, Serial0/0
O IA    172.16.255.4/32 [110/129] via 172.16.100.1, 00:00:24, Serial0/0
O IA    172.16.1.225/32 [110/129] via 172.16.100.1, 00:00:24, Serial0/0
O IA    172.16.1.193/32 [110/129] via 172.16.100.1, 00:00:24, Serial0/0
O IA    172.16.2.0/27 [110/74] via 172.16.100.2, 00:00:24, Serial0/0
O IA    172.16.1.124/30 [110/128] via 172.16.100.1, 00:00:24, Serial0/0
Have you ever have the issue on your real labo or actual environment ?
0 Replies 0
