L2 connectivity issue
Madhu
Hello All,
On checking, the ISE device is not reachable.
From the switch end logs, it's showing connected but not reachable via ping.
Always did shut/unshut to bring up the ISE device. The switch end logs look wired.
What is the meaning of "operational Transmit Flow Control state changed to off"
SW# show int Ethernet1/38 status
Port Name Status Vlan Duplex Speed Type
Eth1/38 *** Connected to P connected 185 full 1000 1000base-T
SW#
Logs:
SW# sh logging | i 1/38
2024 Feb 28 15:26:17.875 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_HARDWARE: Interface Ethernet1/38, hardware type changed to 1G
2024 Mar 1 13:51:24.471 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 1 13:51:24.471 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 1 13:51:24.471 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 1 13:51:24.471 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 1 13:54:12.407 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/38 is down (Link failure)
2024 Mar 1 13:54:18.209 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 1 13:54:18.209 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 1 13:54:18.209 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 1 13:54:18.209 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 1 13:54:18.217 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
2024 Mar 1 13:55:52.885 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/38 is down (Link failure)
2024 Mar 1 13:55:58.754 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 1 13:55:58.754 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 1 13:55:58.754 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 1 13:55:58.754 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 1 13:55:58.763 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
2024 Mar 1 13:59:17.239 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/38 is down (Link failure)
2024 Mar 1 13:59:28.454 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 1 13:59:28.454 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 1 13:59:28.454 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 1 13:59:28.454 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 1 13:59:28.499 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
2024 Mar 1 14:04:12.483 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/38 is down (Link failure)
2024 Mar 1 14:04:18.331 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 1 14:04:18.331 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 1 14:04:18.331 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 1 14:04:18.331 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 1 14:04:18.339 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
2024 Mar 1 14:04:51.922 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/38 is down (Link failure)
2024 Mar 1 14:04:57.712 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 1 14:04:57.712 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 1 14:04:57.712 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 1 14:04:57.712 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 1 14:04:57.722 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
2024 Mar 12 12:59:27.120 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/38 is down (Link failure)
2024 Mar 12 12:59:35.143 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 12 12:59:35.143 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 12 12:59:35.143 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 12 12:59:35.143 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 12 12:59:35.151 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
2024 Mar 19 07:38:25.154 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/38 is down (Link failure)
2024 Mar 19 07:57:05.731 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 19 07:57:05.731 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 19 07:57:05.731 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 19 07:57:05.731 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 19 07:57:05.740 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
2024 Mar 22 12:30:36.681 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/38 is down(Config change)
2024 Mar 22 12:30:36.822 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet1/38 is down (Administratively down)
2024 Mar 22 12:30:38.069 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_ADMIN_UP: Interface Ethernet1/38 is admin up .
2024 Mar 22 12:30:43.795 PHCBU-T7F15W-SF-02 %ETHPORT-5-SPEED: Interface Ethernet1/38, operational speed changed to 1 Gbps
2024 Mar 22 12:30:43.795 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/38, operational duplex mode changed to Full
2024 Mar 22 12:30:43.795 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/38, operational Receive Flow Control
2024 Mar 22 12:30:43.795 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/38, operational Transmit Flow Control
2024 Mar 22 12:30:43.806 PHCBU-T7F15W-SF-02 %ETHPORT-5-IF_UP: Interface Ethernet1/38 is up in mode access
SW#
2 Accepted Solutions
Try hardcoded speed and duplex in SW port
MHM
balaji.bandi
Can you post the configuration applied on the eth 1/38
based on the information of interface it is nexus switch - can you post show nexus version it is ?
check the cables and replace the SFP and test it.
Other suggestion remove the SFP default  the interface and change the speed 1000  and apply relevant config  and inset the SFP, connect ISE and monitor, (check STP config too)
no negotiate auto
speed 10000
duplex full
Also post below output you have still the same issue :
show platform software ethpc event-history interface
BB
MHM
balaji.bandi
no negotiate auto
speed 10000
duplex full
BB
