Join Customer Connection to register!
150
rabeder
Beginner
l3 ip-prec and l2 cos
hi,
i have a router which receives traffic on an ethernet and the router marks this traffic with the ip precedence value from 0 to 5.
the router is then on a second ethernet interface to a third-party switch connected .
now i want that the router also sets the layer2 cos value, so that the switch can do queueing based on the layer2 cos value.
how to do this ?
thanks for answer
1 REPLY 1
carenas123
Contributor
You need to create Class-map and then set CoS value for that class. Refer to the QoS configuration guide for the commands,
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800c75cf.html#wp1005766
