LACP and LAG Phantom Issue
techinneed
Hello all,
Need a little help here.
I have a switchport interface in a port-channel group.  Currently the physcial switchport is not taking any errors, no CRCs, input errors or link status changes.  When I look at the results from a "show interface et1/1", all the values above are zero.
Here is my issue, when I do a "show log", it states the following multiple times:
Lag: %LAG-MEMBER_REMOVED
Lag: %LAG-MEMBER_ADDED
Both entries have the same datetimestamp.
Can someone explain what could cause these multiple bounces?
Thank you!
5 Replies 5
Reza Sharifi
Can you post the config from both sides of the Portchannel?
I do not have the config for the other side as it belongs to a client.
interface po1
   load-interval 5
   ip address 1.1.1.1 255.255.255.252
   spanning-tree bpdufilter enable
interface et1/1
   load-interval 5
   no switchport
   channel-group 1 mode active
   no lldp transmit
   no lldp receive
Hope this helps!
Thank you!
Hey,
what kind of switch do we have here (Model)?
Is this a nexus switch?
Can you post the output of "#show logg | i 1/1"?
Is Et1/1 the only member of the Port-Channel?
If no, please also post the config of the other member ports.
In general it is not a good idea to have the config of the Port-Channel Interface and the physical Interface differentiating like that (in order to not get confused like that).
Try to configure as much as possible from the Port-Channel Interface without touching the physical ones anymore, after setting up the channel.
Cisco Catalyst 9300 Series
switch1 %EC-5-UNBUNDLE Interface Et1/1 has left Port-Channel1
switch1 %EC-5-BUNDLE: Interface Et1/1 has joined Port-Channel1
Yes, Et1/1 is the only interface in the port-channel
I do not understand your statement below:
"In general it is not a good idea to have the config of the Port-Channel Interface and the physical Interface differentiating like that (in order to not get confused like that). >>> What is differentiating that is causing confusion?
Try to configure as much as possible from the Port-Channel Interface without touching the physical ones anymore, after setting up the channel. >>> I do not think I added anything peculiar on either interface"
My config on Et1/1 is generic and the only config I added was "channel-group 1 mode active"
Do you know what may cause this "leaving\joining" the port-channel?
Can you try and rebuild the Portchannel again?
delete po1
no po1
inte e1/1
no  channel-group 1
now rebuild it
inte e1/1
above command will create po1 for you.
now go to po1 and ip
int po1
no sh
verify with command
show etherchannel 1 summary
can you ping 1.1.1.2 if the other side is configured correctly?
