07-07-2015 01:31 PM - edited 03-08-2019 12:52 AM
We need to set up an LACP Port Channel to connect to an EMC Datamover. What would be the best practice configuration. I have found 2 in my research: Should we use switchport mode trunk or switchport mode access.
First:
interface Port-channel1
switchport access vlan 60
interface GigabitEthernet1/0/46
channel-protocol lacp
channel-group 1 mode active
Second
interface Port-channel3
switchport trunk allowed vlan 60
interface FastEthernet0/23
channel-group 3 mode active
Solved! Go to Solution.
07-07-2015 02:05 PM
Good Luck Tom.
Please rate and mark the post as answered so others can benefit from it.
07-07-2015 01:42 PM
If you know you are never going to add a second vlan to the link, first scenario is good enough. If you think you may want to add a second vlan to the same link in the future, you want to trunk it now so in the feature you can always add more vlans to it and no need for down time (second scenario).
07-07-2015 02:00 PM
Reza,
The switch is a single vlan for one application. I will use the first configuration.
Thanks very much for the quick response!!!!!
07-07-2015 02:05 PM
Good Luck Tom.
