02-20-2013 06:59 PM - edited 03-07-2019 11:50 AM
We have a single 4500 connecting to two non-cisco devices. We need to enable port channelling or link aggregation between these two.
The links are carrying mulitple vlans , hence are trunked and the ip address on either side is used for routing.
From each of the two non-cisco device, i am taking 2 ports each to connect to the 4500.
On each non-cisco device side, two ports will bundle together as one aggregated interface (ae1) and the other will be called ae2.
my query is how do i do the configuration for etherchannel on the cisco 4500 side , as it will need two different Po's( port channels).
I need a single ip address on both sides of port channel to be present for routing.
Appreciate all help!
Solved! Go to Solution.
02-21-2013 01:31 AM
Hello Suthomas1,
you need to configure two L2 LACP bundles with different channel group numbers X and Y.
channel group X on interfaces to device1
channel group Y on intefaces to device2
Both bundles will carry the same set of Vlans ( permitted vlans on trunk) this will allow to connect the two non cisco devices through the C4500.
You can use an SVI associated to a vlan permitted over the trunk bundles for this.
Hope to help
Giuseppe
02-21-2013 01:31 AM
Hello Suthomas1,
Hope to help
Giuseppe
02-21-2013 04:57 AM
SW1
interface range fa0/1 - 2
channel-grup 1 mode active
interface port-channel 1
interface range fa0/3 - 4
channel-grup 2 mode active
interface port-channel 2
SW2
interface range fa0/1-2
channel-group 1 mode passive
Interface port-chanel 1
channel-grup 2 mode passive
Do Rate Helpful Posts
