LACP Load Balancing Method
hschlecht
Frequent Visitor
Frequent Visitor
We have two stack of 3750-X switchs interconnected through LACP, and a CheckPoint Firewall connected to one of the stack. The Firewall use a LACP bond to connect to the 3750-X Stack. On the Cisco switches we don't use any Layer3 functionality.
Since the switch are used in Layer2 mode, can we define the a load balancing method that use IP informations ?
For example Can we change the load balancing method from src-mac to src-dst-ip ?
BRgds
5 Replies 5
chandra_rc16
Level 7
Level 7
As far as i know. Yes we can configure loadbalancing based on source & destination IP. The switch can understand it in though in layer2 mode.
Chandu
Regards, Chandu
yes you can choose the method of Load balancing in LACP:
port-channel load-balance {dst-ip | dst-mac | src-dst-ip | src-dst-mac | src-ip | src-mac}
Configure an EtherChannel load-balancing method.
The default is src-mac.
Select one of these load-distribution methods:
•dst-ip—Load distribution is based on the destination-host IP address.
•dst-mac—Load distribution is based on the destination-host MAC address of the incoming packet.
•src-dst-ip—Load distribution is based on the source-and-destination host-IP address.
•src-dst-mac—Load distribution is based on the source-and-destination host-MAC address.
•src-ip—Load distribution is based on the source-host IP address.
•src-mac—Load distribution is based on the source-MAC address of the incoming packet.
Hello, It's completed in these mechanisms (Q1 2023):
  • gtpu: IP and GTP-TEID
  • inner-header: Inner header
  • ip: IP
  • ip-gre: IP, GRE key
  • ip-l4port: IP and L4 port
  • ip-l4port-vlan IP: L4 port and VLAN
  • ip-vlan:  IP and VLAN
  • ipv6-flow-label: IPv6 Flow Label
  • l4port: L4 port
  • mac: MAC
  • mac-ip-l4port-vlan: MAC, IP, L4 port and VLAN
BTW, LB defaults and choices can vary per platform.
Joseph W. Doherty
Yup, as also noted by other posters.
3750 series can work with L3 info even in L2 mode.
